It is currently Oct Wed 21, 2020 12:59 am
 Post subject: Zenith 801 radio cabinet refinish and veneer restore. (Done)
PostPosted: May Mon 25, 2020 3:00 am
This little uncommon zenith 801 came over for a fresh makeover , body work and paint as they say in the body shop, it came from one our club members here on the forum as did the zenith tombstone that on another thread now , cabinet sure does need it. The book matched walnut veneer on each side is shot along with the inlay, missing half of it and is bubbled up bad.. Will apply new book matched burl veneer and replace the checkered inlay, Stay tuned in if you want to see this little one come out looking like a jewel off a pirates ship.
File comment: Carefully remove old veneer , im using a small carving tool, wasn't meat for this but works well just try and not gouge the sub straight wood.
File comment: Veneer removed on ether side and stripped down, sanded. A number of areas needed to be reglued to make a tight cabinet and veneer that was lose.
File comment: Fabricated 2 new wood corner blocks to support the feet. One was missing and the other broken in half.
File comment: Ready for new book matched walnut burl, now waiting arrive in mail in a few daze.
File comment: Gap in the outside corner will repair this i cant squeez together so I will do a little trick, probably been around before just came to me. Gluing a piece of veneer in the gap and carve and sand to contour
File comment: Glued in ready for carving and sanding to shape.
 Post subject: Re: Unknown Mantel radio cabinet and veneer restore.
PostPosted: May Mon 25, 2020 3:02 am
Does this cabinet have the electronic guts available ?
PostPosted: May Mon 25, 2020 3:16 am
hello Fred,
you have your work cut out on this job
Sincerely Rich
PostPosted: May Mon 25, 2020 1:15 pm
The owner of this radio has all the parts to it, I'm just doing the cabinet for him.
PostPosted: May Mon 25, 2020 1:18 pm
radiorich wrote:
hello Fred,
Sincerely Rich
Actually this is a routine and common repair really not that difficult.
PostPosted: May Mon 25, 2020 1:24 pm
I will be following, Please explain procedure as you go.
Scott
If you can't explain it simply, you don't understand it well enough
A.Einstein
PostPosted: May Mon 25, 2020 11:22 pm
Fred,
It is a Zenith 801.
Barry
PostPosted: May Tue 26, 2020 12:18 am
Ok Barry thanks.
 Post subject: Re: Zenith 801 radio cabinet refinish and veneer restore.
PostPosted: May Wed 27, 2020 1:55 am
Heres the corner gap problem that was repaired. That there is a good repair something that will last. This cabinet was suffering from some water damage the problems it sustained was from water no doubt. I did notice a older veneer repair on the top and will see if the customer wants it replaced while in surgery. Shown in one picture see if you can spot it out.
File comment: Can you see it? on the center top stepped up portion of the cabinet. The cabinet had been repaired and refinished before I could tell.
PostPosted: May Wed 27, 2020 1:57 am
hello fred,
looking better
 Post subject: Re: Zenith 801 radio cabinet refinish and veneer restore. (D
PostPosted: Jun Tue 02, 2020 2:34 pm
Ok this little Zenith Mantel is finished as well and came out of surgery with flying colors. Some what of a time consuming effort even though its a little cabinet it made it though nice and solid cabinet with the new walnut burl veneer and factory patterned inlays strips across the front . Water must have gotten on the cabinet at some point and did some damage to the veneer . I think now the cabinet looks very nice again, time consuming tedious job but well worth the effort to save this piece of Zenith history. Thanks for looking.
File comment: Templets were made to place on the new veneer to line up for book matching and for fit.
File comment: Yellow glue applies on cabinet as well for the new veneer
File comment: New veneer now ironed down with heat from household iron. Overlapping a little on the outside edges and will be trimmed off and sanded smooth.
PostPosted: Jun Tue 02, 2020 3:23 pm
fred taylor wrote:
radiorich wrote:
hello Fred,
Sincerely Rich
It may not be that difficult for you because you have the tools, experience and expertise to do it right. I look at the before and after pictures on your posts and to me what you do is indistinguishable from magic. You, sir, are an artist of the highest caliber and I'm in awe of your skill.
PostPosted: Jun Tue 02, 2020 5:08 pm
Fred, Big thanks for sharing the procedure... I learn a lot from your posts.
Scott
A.Einstein
PostPosted: Jun Wed 03, 2020 2:30 am
Wow Fred! This is a fabulous transformation on this little guy. Great job.
Post New Topic Post Reply  [ 14 posts ]  Moderator: Peter
Users browsing this forum: CRTag55, otherzenithguy, Sandy and 9 guests
