It is currently Oct Tue 19, 2021 3:00 am
 Post subject: Why Stain Is So Useful
PostPosted: Aug Fri 27, 2021 4:02 am
When you strip an old lacquer finish using lacquer thinner / acetone, you find that the wood had some color, known at patina. However, you may need to make repairs with new veneer, and sand areas, plus you use grain filler. Stain is very useful for achieving a nice even tone before you start to apply lacquer. The alternative is to apply heavy costs of tinted lacquer, obscuring the patina and grain. Of course, too much or too dark stain will do much the same thing!
Here is a photo of the top of a Philco I am restoring after application of the grain filler.
 Post subject: Re: Why Stain Is So Useful
PostPosted: Aug Fri 27, 2021 4:47 am
While not used originally, I always stain the veneer after stripping. The less lacquer and toner needed, the better.
My favorite is Minwax English Chestnut.
PostPosted: Aug Fri 27, 2021 6:26 am
Are you using clear or tinted/colorized grain filler?
PostPosted: Aug Fri 27, 2021 1:00 pm
The grain filler I have used for refinishing has always dried to a very light color, so I tint it.
After tinting the filled pores of the wood will look darker and more like the original finish did.
Paul
...... how hard can it be?
PostPosted: Aug Fri 27, 2021 6:03 pm
Hi Paul -
I was just about to experiment with tinting some grain filler when I read your post.
Are you using Timbermate grain filler? Can you elaborate a little on what you tint it with? Are you using stain to tint it or some sort of dye? I assume your process is to tint first then apply. Does the tinting alter the drying properties of the grain filler at all?
PostPosted: Aug Fri 27, 2021 7:01 pm
Mark, the last filler I used was a Benjamin Moore product. It is oil based and I used a Minwax walnut stain, also oil based, to tint the filler to a darker color.
I am not sure whether it slows the dry time or not since I never have used the untinted filler or tested the dry time of it.
I usually apply the filler across the grain with plastic scraper then allow to semi dry before rubbing down with a rag.
Paul
PostPosted: Aug Sat 28, 2021 12:07 am
I used to use Constantin's darkest wood grain filler. It was moderately hard to fill all the pores on some particularly open/figured grains and as an oil base (thinned with mineral spirits) which meant it would change the color of any oil based stains applied prior to the grain filling. I wouldn't call myself an expert by any means, but my original refinishing procedure used to be oil based minwax stain for coloring, followed by grain filler, followed by clear coats. This meant that if you had two different colors of stain next to each other, say for a two tone color scheme, if they used the same veneer the grain filler would end up blending the line between the two. I tried taping and found that it would weep under the tape or the tape would pull the grain filler out of the pores. I loved the product though (its since been discontinued).
Aquacoat grain filler works very well, so far I have only used clear and I plan to buy my next can in a dark tint to see how they compare. Much easier to fill all the pores in 1-4 coats. But, the product only lasts like six months after opening, cannot be allowed to freeze (so if its shipped in winter you might be SOL). Does not cause me any bleeding or blending of stains, probably because its a water base. Scentless and can be done indoors with no ventilation. I also love this product but it has its drawbacks and limitations.
In the 90s my grandfather used very thinned and DIY-tinted DAP "Plastic Wood" as grain filler (not an intended application of the product, manufacture does not advertise or recommend doing this). He had good success with it, but I was never able to get it down/learn enough about his technique to duplicate it before he passed.
PostPosted: Aug Sat 28, 2021 3:10 am
I used mahogany Timbermate. It is too light. The cabinet is now stained and waiting until I have time to work on it, probably Sunday.
PostPosted: Aug Sat 28, 2021 7:24 pm
I'm using timbermate. I thin it, which lightens it up, so sometimes I have to tint it. I really like the water cleanup. I use both the walnut and natural. The walnut, which is very dark, fills the pores with a nice dark look, as long as I haven't thinned it too much, and looks very natural on any medium to dark veneers. Like I mentioned, I do tint my fillers if required. I use transtint liquid dyes. Remember, the filler ALWAYS goes lighter after it dries. On medium to dark wood, a dark filler ALWAYS looks better than a filler that is too light.
PostPosted: Aug Mon 30, 2021 12:05 am
Here is the top with a few coats of lacquer
Users browsing this forum: k9uw and 2 guests
