It is currently Oct Sat 23, 2021 12:37 am
 Post subject: Vintage GE Radio Console 81927 -
PostPosted: Sep Sat 11, 2021 2:22 pm
I have inherited this GE radio which needs a lot of repairs. First, can the broken grill be repaired and how? Should I sand the veneer, replace the broken pieces or what are my options?
I am new at this and can use all the suggestions I can get.
Thanks in advance, Robin
 Post subject: Re: Vintage GE Radio Console 81927 -
PostPosted: Sep Sat 11, 2021 11:26 pm
I would simply polish that cabinet. It looks better than many. As far as that broken bar, contact a member down near Dallas. If you can remove and send it, that should be easy. By the way, that radio has the obselete F.M. band. Not real common. Craig
PostPosted: Sep Sun 12, 2021 2:39 pm
Thank you for replying. Do you have a suggestion for the top of the console? Should I glue it? Or try to piece in new veneer?
Thanks again, Robin
PostPosted: Sep Sun 12, 2021 3:19 pm
If you're just starting out, l would just put veneer pieces there and glue. It won't look perfect but it's better. Otherwise the center top should be re-veneered. I have an RCA whose front panel was unevenly glued from the factory....75 years later much had cracked and peeled. Craig
PostPosted: Sep Tue 14, 2021 7:59 am
That is the sort of top that is difficult to repair as the top, and control panel, are essentially one piece. The least I can say is that the veneer is not damaged on the curve. Anyhow the problem is that the end of the panel that is damaged is obscured by a piece of molding as it curves down the front, unless I'm not viewing it correctly.
Regards
Arran
Post New Topic Post Reply  [ 5 posts ]  Moderator: Peter
Users browsing this forum: No registered users and 16 guests
