It is currently Jan Sun 23, 2022 11:29 pm
 Post subject: Painting White Radio Red
PostPosted: Oct Tue 05, 2021 6:07 pm
Hi Guys:
I want to experiment a bit with painting Bakelite radios. I have a white painted bakelite radio with a couple of minor wear-through spots that I'd like to paint bright red or possibly even metallic red. I'm thinking of using Duplicolor Auto touch-up spray to do the job. Any tips for prep and steps and is Duplicolor a good choice for paint? Thanks!
 Post subject: Re: Painting White Radio Red
PostPosted: Oct Wed 06, 2021 1:49 am
Give it a good sanding and remove any glossy surfaces so that the new finish will "bite" down on the original finish.
PostPosted: Oct Thu 07, 2021 4:24 am
Should I use primer? Has anyone used Duplicolor paints and what kind of results did you get?
PostPosted: Oct Thu 14, 2021 3:06 am
Wouldn't hurt to use primer, never used duplicolor, I'm sure it's pretty good. I usually use Krylon.
Post New Topic Post Reply  [ 4 posts ]  Moderator: Peter
