It is currently Feb Sat 04, 2023 2:58 pm
 Post subject: Knob brights for Zenith Transoceanic A600L?
PostPosted: May Thu 19, 2022 2:59 pm
Just finished a resto of one of these and the one last thing I need is a knob bright for the tuner knob. Been looking around online and it seems these are scarce. If anybody has any secrets on how to get a hold of some of these please let me know. Thanks!!
 Post subject: Re: Knob brights for Zenith Transoceanic A600L?
PostPosted: May Wed 25, 2022 4:26 pm
I was able to get brights for my Zenith radio on eBay. I had to look for them for several months before they showed up. There is a person that sells them but I no longer have the info on them. I will post when I find him.
Dwight
PostPosted: May Wed 25, 2022 4:37 pm
Here are some for sale on eBay:
https://www.ebay.com/itm/175292379534?h ... Sw8RFii5w7
Dwight
PostPosted: May Wed 25, 2022 9:08 pm
Tom Johnson talked about making new brights on FB that he would be selling. He is also the gentleman who builds the FILT-R-PAK for TO's you see on Ebay. I guess he's selling them now as Dwight showed us. I mentioned the problem of getting the old brights off the knob. This is his resonance.
If a #11 EXacto blade can't be inserted under an edge without damaging the knob, you can use a small drill bit (1/16" or so) and drill from the back through the control shaft hole to yield a hole at or near the center of the old bright to get a sharp instrument into. Bill Crump used to recommend a small rotary saw blade on a Dremel tool to cut an "X" at the peak of the old one so as to get a tool underneath and lift it off. Either, or a combination of the two should work without damage to the knob. Going back on, the new one is secured with a small dot of white craft glue, and using too much may result in glue oozing out around the edges. If so, use a toothpick while the glue is wet to remove excess and follow with a paper tower and Windex (or similar) to remove smears, etc.
Sounds like it might work. I'm looking into another way. We'll see what happens.
Freeman
What's built by man can be fixed by man.
Users browsing this forum: AuroraOldRadios, bfrederi and 8 guests
