Page 1 of 1
[ 8 posts ] |
Author |
ktewell
Post subject: Large dent Posted: May Sat 14, 2022 11:28 pm |
Member |
What is the best way to repair a large dent.
Attachments: |
_________________ Kevin....
Top |
Mr Peabody
Post subject: Re: Large dent Posted: May Sat 14, 2022 11:59 pm |
Member |
Prick it deeply in several places with a pin. Then steam it out with a clothes iron. May take quite a while but eventually it should swell back out. You can also just put a wad of paper towel soaked in hot water on it. Keep replacing with hot water and in a few days...voila! Steam works faster but be careful. Pricks are necessary to let the water penetrate the finish. https://www.youtube.com/watch?v=c75LWAmWeBQ
Top |
markg123
Post subject: Re: Large dent Posted: May Mon 16, 2022 7:20 pm |
Try a soldering iron in lieu of the clothes iron, but with the same elements previously described (prick it, wad of wet paper towels or rag, t-shirt, etc.). That dent looks like something round fell on it, crushing the wood fibers. A soldering iron - not the tip but higher up towards the handle - looks like it would be a good fit.
Top |
ktewell
Post subject: Re: Large dent Posted: May Mon 16, 2022 7:35 pm |
Member |
Thanks everyone for the advice. I am going to try it.
Top |
GalaxyBeing
Post subject: Re: Large dent Posted: May Tue 17, 2022 2:15 am |
Member |
ktewell wrote: Thanks everyone for the advice. I am going to try it. Good luck. Please remember to post back on the results.
Top |
ktewell
Post subject: Re: Large dent Posted: May Sat 28, 2022 11:16 pm |
Member |
Came out good I used a x-acto blade to get under the wood and help lift it up.
Attachments: |
Top |
Scott
Post subject: Re: Large dent Posted: May Sat 28, 2022 11:46 pm |
Member |
I would use a syringe and some thin CA glue to inject under the loose wood and lock it into place.
Top |
ktewell
Post subject: Re: Large dent Posted: May Sat 28, 2022 11:48 pm |
Member |
I did, a lot of glue….
Top |
Page 1 of 1
[ 8 posts ] |
Moderator: Peter |
Users browsing this forum: No registered users and 9 guests |
