It is currently Oct Mon 18, 2021 7:54 am
Post New Topic Post Reply  [ 33 posts ]  Go to page 1, 2  Next
 Post subject: Electronic Designs Inc Model 100 VTVM
PostPosted: Sep Wed 22, 2021 6:14 am
I'm on to another one. For some reason I seem to like the oddball ones with no information available lol. It's an Electronic Designs Inc VTVM. It has a 6X5 tube on the right and 2 6K6 tubes on the left.
The resistance ranges work although not dead on.
The AC ranges look pretty good. The DC ranges are off a bit off. Does anyone have any thoughts or ideas on how to calibrate this meter? Here is the calibration pots inside. It's close but that's only good in handgrenades lol. I'm also looking for a schematic with no luck so far. Any help, thoughts or ideas would be greatly appreciated.
Thanks.
Robb
 Post subject: Re: Electronic Designs Inc Model 100 VTVM
PostPosted: Sep Wed 22, 2021 6:20 am
The meter looks a lot like the one in the EICO 221.
PostPosted: Sep Wed 22, 2021 6:26 am
From Vacuum Tube Voltmeters, Rider, 1951
Yes it's not exact but it's close.
Thanks.
Robb
PostPosted: Sep Wed 22, 2021 6:27 am
K7MCG wrote:
My God man. Thank you.
Thanks.
Robb
PostPosted: Sep Wed 22, 2021 2:42 pm
Most of the design of the Model 100 VTVM was taken from the RCA model 195-A voltohmist. The model 100 replaced the vacuum tube AC rectifier in the 195-A with a pair of semiconductor diodes. Therefore, the RCA model 195-A calibration instructions which are included in https://bama.edebris.com/manuals/rca/195a/ will apply to the model 100.
PostPosted: Sep Wed 22, 2021 2:53 pm
Thank you.
Thanks.
Robb
PostPosted: Sep Wed 22, 2021 3:10 pm
The 195-A is close but all the ranges are different. I have a 3VDC scale and a 3VDC adjustment pot. I also have a 10VAC scale and a 10VAC adjustment pot. The last adjustment pot is a 100VAC. It has a 10VAC scale and a 30VAC scale on the meter face. I'm in search of better calibration instructions and possibly the manual?
Thanks.
Robb
PostPosted: Sep Wed 22, 2021 6:45 pm
Without power adjust the meter so that the pointer is at 0. Then warm up the meter and short the leads together and adjust the front panel 0 adjust pot so that the meter reads 0. Then apply 3vdc to the meter and adjust the 3vdc pot so that the meter reads 3 volts DC, then repeat the front panel 0 adjust procedure and apply 10vac to the meter and adjust the 10vac pot so that the meter reads 10 volts AC, finally repeat the front panel 0 adjust procedure and apply 100vac to the meter and adjust the 100vac pot so that the meter reads 100 volts AC.
PostPosted: Sep Wed 22, 2021 7:13 pm
Thank you. I've actually done this. Lol. It made sense to me. But then you see other calibration procedures and it's set to 4VDC on the 5VDC scale.
Thanks.
Robb
PostPosted: Sep Wed 22, 2021 9:13 pm
This meter is unusual in that the AC section is simply a VOM rather than a VTVM. In the AC position, the panel meter is disconnected from the VTVM electronic circuitry and connected to what is essentially the AC portion of a VOM. So in AC mode, the front panel zero adjust control shouldn't have any effect on the meter.
in my reading of the schematic, the two AC adjustments shown there should interact, so it's not clear to me what procedure should be followed to adjust them. One adjustment controls the shunt resistance across the meter. The other controls the calibration of the 10 Volt scale, with proportionately smaller effects on the higher scales.
I think I'd start by adjusting R33 so that the series combination of R33 and R34 is 10,000 Ω. (This is clearly a 1,000 Ω/V AC meter.) I'd then apply 100 Volts AC and adjust R31 until the meter reads 100 Volts. Next, I'd apply 10 Volts and adjust R33 so that the meter reads 10 Volts. Then I'd repeat the 100 Volt and 10 Volt adjustments.
PostPosted: Sep Wed 22, 2021 9:26 pm
Your correct in that in AC mode the front panel zero adjust has n9 effect on the needle. The above procedure gets me close on all scales but not dead on. I will try your procedure after I get home from work at 1130 and let you know. Thanks.
Thanks.
Robb
PostPosted: Sep Wed 22, 2021 10:01 pm
Robbdoe1, you seem to be interested in restoring VTVMs, so you'll probably be interested in these links to scans of the two most common books written about them.
First, Rider's Vacuum Tube Voltmeters is available from the excellent tubebooks.org site:
http://tubebooks.org/Books/rider_VTVM.pdf
Second, Rhys Samuel's excellent The VTVM is available in several editions:
First printing, 1956: https://worldradiohistory.com/BOOKSHELF ... l-1956.pdf
Eighth printing, 1962: https://worldradiohistory.com/BOOKSHELF ... 7-1956.pdf
A nice hi-res scan of the Fifth printing, 1960: http://www.vacuumtubeera.net/The-VTVM-R ... l-1956.zip
ARFer ncwalz's nice scan of the Second printing, 1957: http://www.mediafire.com/file/abz95ndxa ... l.pdf/file
Rider's book is especially valuable because it includes schematics for many commercial VTVMs, along with calibration instructions for some of them.
PostPosted: Sep Wed 22, 2021 10:08 pm
Yes VTVMs and analog multimeters that are vintage. Thank you so much for the links. I will dl them tonight.
Thanks.
Robb
PostPosted: Sep Wed 22, 2021 11:36 pm
The reason behind calibrating at, say, 4V on the 5V scale is to average the nonlinearity. If you calibrate zero and full scale, the long stretch between may not be very linear. When you set it at maybe 80% of full scale, the space between known points is smaller and thus has less chance of losing accuracy.
I didn't explain that too well but maybe you can get it.
PostPosted: Sep Wed 22, 2021 11:50 pm
Yes I understand. It makes sense if you think about it....it may also be why the meter is off a little using the above common sense method. 10VAC scale and 10VAC pot calibrate to 10VAC lol. Your only getting zero and 10VAC calibration and the in-between....or linearity may be off. Thanks for the insight.
Thanks.
Robb
PostPosted: Sep Wed 29, 2021 11:48 pm
I'm back at it again. I tried this procedure above but the meter will not adjust to 100 Vac. 10 Vac with the 10 volt pot is no issue. It reaches about 80 to 90 percent of it's way to 100 Vac when adjusting the 100 volt pot. The pot reaches it's mechanical stop before I can reach 100 volta on yhe AC scale.
Any ideas?
Thanks.
Robb
PostPosted: Oct Tue 05, 2021 2:33 pm
I'm making a dedicated DC probe for this meter. Can anyone tell me IF it uses a series resistor? If it does, what size? Some of my VTVM's use a 1M ohm resistor and others use a 6.8M ohm. Is there a way to tell without a manual? Thanks guy's.
Thanks.
Robb
PostPosted: Oct Tue 05, 2021 4:25 pm
A series resistor in the DC Volts probe is an essential feature in service-grade VTVMs. (Some laboratory grade VTVMs don't have it, though.) So yes, it almost certainly uses a series resistor.
If it's not shown on the schematic, and you don't have the specification for the DC input impedance, there's no way to be certain of its value.
You mentioned that the DC volt ranges were a little off when you first tested it. How much were they off, and in what direction? And what is the resistance of the DC Volts range divider, from the connector to ground (i.e. the sum of R-1 through R-6)?
If they were about 10% high, and the total resistance of the DC volts range divider is 10 Megohms, then the probe almost certainly had a 1 Megohm resistor in it.
PostPosted: Oct Wed 06, 2021 4:18 pm
Hello and thank you.
The sum of R1-R6 is 11M ohm. The DC readings are low to start my test. 2.6VDC on the 3VDC scale, 8.7VDC on the 10VDC scale and 25VDC on the 30VDC scale using my adjustable power supply and confirming with my Fluke. The DC probe I used has the ability to add a 1M ohm resistor in series with the probe tip or short the tip directly. The above reading were taken with the tip shorted directly. When I added in the 1M ohm resistor the readings dropped even lower. If I attempted to calibrate it on the 3VDC range I ran out of adjustment on the 3VDC pot and could not achieve calibration.
I then calibrated the DC via the 3VDC pot in the rear of the meter. I set the power supply to 3VDC and the meter to the 3VDC range. I adjusted the pot to achieve exactly 3VDC with the probe tip shorted directly. So obviously on the 3VDC check it was dead nuts, on the 10VDC check it was above the 10VDC tic on the meter face (see pictures) and on the 30VDC check it was slightly below the 30VDC tic on the meter face (see pictures). I have no way yet to verify the 100VDC, 300VDC or 1000VDC ranges currently.
What would you make of this? Is there anything I'm missing? The only other adjustment pots are 10VAC and 100VAC which when turned had no affect on the DCV readings. For clarification I zeroed the meter with power off mechanically. I also zeroed the meter in every DC range I went to.
Thanks.
Robb
