Page 1 of 1
[ 9 posts ] |
Author |
Garry777
Post subject: Adding Ferrite Beads to TV-7 Tube Tester to stop Oscillation Posted: May Sat 21, 2022 8:18 pm |
Does anyone have knowledge about adding ferrite bead(s) to a TV-7B/U Tube Tester circuit to stop oscillation in a tube being tested. I'm having problems with an old 6L6GB tube that goes into oscillation when tested on my TV-7B/U tube tester. I know that a ferrite bead is used on a wire going to the 8-pin test socket (I just cant remember the pin #). Thanks for all replies.
Top |
bob91343
Post subject: Re: Adding Ferrite Beads to TV-7 Tube Tester to stop Oscilla Posted: May Sun 22, 2022 12:41 am |
It probably doesn't matter. I'd select the plate or control grid first.
Top |
Barry H Bennett
Post subject: Re: Adding Ferrite Beads to TV-7 Tube Tester to stop Oscilla Posted: May Sun 22, 2022 12:58 am |
Member |
Joined: Nov Wed 30, 2016 7:35 pm Posts: 12232 Location: Sunbury, Ohio 43074
Some testers use ferrite beads on every lead, to every socket. More's better. If you have the beads, and the time, I'd add them to at least the sockets you use most. I'm not sure if the later TV7's had them or not, but many of the non military Hickoks do.
_________________ Preserving the hist. of electronics, one boat anchor at a time! :) https://www.bbtvtestequipment.com
Top |
DrRick
Post subject: Re: Adding Ferrite Beads to TV-7 Tube Tester to stop Oscilla Posted: May Sun 22, 2022 2:39 am |
Joined: Mar Thu 24, 2011 6:23 am Posts: 635 Location: New Jersey Shore 08724
My TV-7D/U has them everywhere. I think that’s exclusive to the “D/U” version.
Peace, DrRick
Top |
hwhall
Post subject: Re: Adding Ferrite Beads to TV-7 Tube Tester to stop Oscilla Posted: May Sun 22, 2022 5:00 am |
Joined: Jan Sat 25, 2020 5:23 am Posts: 1099 Location: Colorado Springs, CO 80917
Quote: 6L6GB tube that goes into oscillation Curious about the observed symptoms when it goes into oscillation. What happens? FWIW, my Hickok 6000A has ferrite beads on all the socket island leads at the mating plug.
Top |
KX5JSC
Post subject: Re: Adding Ferrite Beads to TV-7 Tube Tester to stop Oscilla Posted: May Sun 22, 2022 6:28 am |
Joined: Dec Sat 28, 2019 4:18 pm Posts: 1327 Location: Corinth, TX
I have always wondered: Which ferrite beads? Or does it matter?
Top |
CurtisL
Post subject: Re: Adding Ferrite Beads to TV-7 Tube Tester to stop Oscilla Posted: May Sun 22, 2022 2:13 pm |
I added beads to the 7, 9, and octal tube sockets on a TV-7A. Testing 6DJ8/6922 tubes on the TV-7A was almost impossible without them. Even getting your hand close to that tube would cause the meter to jump upscale during testing.
Top |
Barry H Bennett
Post subject: Re: Adding Ferrite Beads to TV-7 Tube Tester to stop Oscilla Posted: May Sun 22, 2022 2:31 pm |
Member |
KX5JSC wrote: I have always wondered: Which ferrite beads? Or does it matter In this case, it probably makes little difference which bead you use. You are trying to suppress high frequency oscillations in a circuit where everything else is at relatively very low frequency. Nothing critical here.... other than the fact that they have to fit in there mechanically
Top |
ACORNVALVE
Post subject: Re: Adding Ferrite Beads to TV-7 Tube Tester to stop Oscilla Posted: May Mon 23, 2022 12:05 am |
The easy way to do it is to just make a socket adapter with a resistor, typically 4.7k to 10k in series with the g1 grid. You could also place a 47R resistor in series with the anode, or both. This will kill the parasitic oscillations, better than the ferrite beads.
Have you checked the 2700pF capacitor , designed to suppress HF oscillations, in the anode circuit of the tester ?
Top |
Page 1 of 1
[ 9 posts ] |
Who is online |
Users browsing this forum: sdfzaqhp659 and 22 guests |
