It is currently Jul Mon 04, 2022 11:18 pm
 Post subject: Need service manual for Xytronic Supertech 999SD
PostPosted: May Fri 30, 2014 1:54 am
Hello All,
I need service manual for Xytronic Supertech 999SD as when I use the vaccum (sucker) it blows the 3A fuse.
Any help please.
 Post subject: Re: Need service manual for Xytronic Supertech 999SD
PostPosted: May Fri 30, 2014 5:37 am
Send your email address and I'll send you a scan of the manual.
-Chuck
PostPosted: May Fri 30, 2014 4:37 pm
HI:
SOUNDS LIKE A MECHCANICAL PROBLEM HAS CAUSED AN ELECTRICAL PROBLEM.
IT IS POSSIBLE THE VACUUM MOTOR MAY HAVE SHORTED.
WALTER-W2WIQ
PostPosted: Jun Tue 03, 2014 12:23 am
Thanks Chuck - K7MCG for the manual. I am in the process of replacing C11 as you requested, I will post the results.
Hello Walter - W2WlQ
Thanks for the input, I disconnected the pump motor and supplied power to it and it works fine.
Cheers
Chris
PostPosted: Jun Tue 03, 2014 1:01 am
HI CHRIS:
I ONLY MEENTIONED THAT BECAUSE EVERY ONE I HAD TO REPAIR HAD A SHORTED MOTOR WITH A JAMMED SHAFT.I HAD TO HAVE THE MOTORS REWOUND.
THE MOTOR SHOULD BE LUBRICATED WITH A LIGHT MACHINE OIL WHILE YOU HAVE IT APART.
GOOD LUCK.
WALTER-W2WIQ
PostPosted: Jun Tue 03, 2014 11:52 am
Hello Walter,
When you say lubricate the motor do you mean the shaft or pump area? I assume the shaft but not the pump. Is this correct?
Cheers
Chris
PostPosted: Jun Tue 03, 2014 2:19 pm
HI CHRIS:
I DO NOT KNOW HOW YOUR MOTOR AND PUMP ARE ASSEMBLED.I AM REFERRING MAINLY TO THE MOTOR LUBRICATION.USUALLY AT EACH END OF THE MOTOR THERE IS A SMALL LUBRICATEING HOLE AT THE TOP.
WALTER-W2WIQ
PostPosted: Jun Wed 04, 2014 12:04 pm
Hello Chuck,
It was C11 capacitor as you mentioned all good now many thanks
Chris
PostPosted: Jun Wed 04, 2014 12:11 pm
Hello Walter,
The bearing on the motor is a sealed one. It moves freely without any effort, however I did have a look and cleaned around a bit, my problem was a ceramic capacitor (C11) on the board which Chuck-K7MCG helped me find and now it works great.
I thank you for you input, I think the pump needed a clean anyway and now works great.
Many thanks
Chris
PostPosted: Jun Wed 04, 2014 12:48 pm
HI CHUCK:
GREAT
THAT WAS A CHEAP EASY CURE.
AN OUNCE OF PREVENTION IS WORTH A POUND OF CURE.
WALTER-W2WIQ
PostPosted: Feb Mon 13, 2017 12:52 pm
If anyone in this discussion has a PDF copy of the manual on the 999SD-A I sure would appreciate an emailed copy. I just picked one up at a hamfest this weekend (in working order) and I'd really like to have the documentation on-hand, as it will probably see pretty regular use on my workbench. I also snagged a 966D which has a vacuum issue, if anyone happens to have a scan of that manual as well.
Thanks in advance for any help finding documentation on these!
Dan / KK4ICE
PostPosted: May Sun 29, 2022 9:09 am
My 999sd vacuum pump is not happy.
I have had a long time and it has been reliable.
Since I have spare tips and stuff I would prefer to repair it.
A schematic would be awesome
Any other tips are appreciated as well.
Many thanks!
PostPosted: May Tue 31, 2022 4:57 pm
Hello everyone,
I've owned this soldering station for an hour.
I got them cheap from a flea market. Unfortunately, the heating element for desoldering does not work on mine. When the plug is in, the pointer rises just a little bit. When I unplug the connector, the pointer swings all the way to the end. Does anyone have the wiring diagrams for me?
The resistance values ‚Äč‚Äčof the heating element and thermistor would also be enough for me to check
best regards Klaus from Germany
PostPosted: Jun Sun 05, 2022 11:13 am
Hello Klaus,
I sent you the PDF diagrams for the Xytronic Supertech 999SD, Here are the files.
SUPERTECH 999SD-A.pdf [1.81 MiB]
Downloaded 15 times
Xytronics Supertech 999SD.pdf [946.08 KiB]
Downloaded 14 times
PostPosted: Jun Sun 05, 2022 10:33 pm
Thank you, cso5. !!!
Users browsing this forum: Google [Bot], jethro98, sdfzaqhp659 and 17 guests
