It is currently Nov Tue 24, 2020 2:49 am
 Post subject: TS-352/U military meter manual request
PostPosted: Jun Thu 11, 2009 1:56 am
Hi folks,
I have just acquired a TS-352/U military multimeter, and I do not have a manual at the current time. A friend of mine had a PDF, but he deleted it, and was not successful in his attempt to recover the thing. Does anyone out there happen to have a PDF of the manual for this critter ?? It looks OK, have not opened it up yet, but I aim to do that here soon. I am thinking that most likely all it will need is a simple fix like contact cleaner and a coat of paint to get it running. Any assistance on this would be greatly appreciated ! Thanks,......Tom
BTW- If you have a pdf of the manual, feel free to email me at : signalcorpsoperator@gmail.com. Thank you.
PostPosted: Jun Thu 11, 2009 2:46 am
Check your email...
PostPosted: Jun Thu 11, 2009 3:09 am
Hi Don-
Many thanks ! I greatly appreciate it ! 73's,..........Tom
 Post subject: TS-352/U me-9e/u military multimeter
PostPosted: May Mon 31, 2010 10:22 pm
Hi, I also just acquired one of these and could use the pdf manual??? appreciated, email johndp58@verizon.net
PostPosted: Jun Tue 01, 2010 12:54 am
Email Sent !!!
"PRO PATRIA VIGILANS"
(Watchful for the Country)
 Post subject: info received
PostPosted: Jun Tue 01, 2010 1:57 am
thanks much Tom!!!!!! John P.
PostPosted: Jun Tue 01, 2010 2:56 am
No problem John !
Have fun with the meter !!!
 Post subject: Re: TS-352/U military meter manual request
PostPosted: Sep Wed 12, 2012 9:48 pm
Hi guys,
I am the next lucky owner of the TS-352 B/U.
Swiped practically a new unit, for 50 bucks. All wires and leads in place.
The battery compartment is clean as a whistle. Works fine - checked the DC/AC. Of course the Ohms won't work without batteries, but I primarily needed a Voltmeter that can switch between 1kOhm/20kOhm per volt on DC.
For that matter, the DC is spot on. AC is different from the DMM reading but then I am not sure TS-352 is "true RMS" type. Still would like to know why the difference is there.
Anyways, would be nice to have the manual with the schematic of it, so I'd appreciate if someone could share it with me.
PostPosted: Sep Thu 13, 2012 6:07 am
You can download the calibration and spec's here
http://www.simpson260.com/downloads/tb9 ... 352-35.pdf
PostPosted: Sep Thu 13, 2012 6:22 pm
Thanks, yes the calibrations pecs - found them yesterday.
I actually wanted to see the schematic, and the manual I need to see how the 5kV converter operates. And old manuals often times did have schematics in them.
PostPosted: Sep Fri 14, 2012 4:52 pm
morzh
http://www.isurffish.com/arf/pdf/ts-352-15.pdf is a copy of TM 11-6625-366-15 dated January 1967 Multimeter TS-353B/U. It has the schematic that you are looking for. I also I have the printed manual and can take it Kinkos to make a full size copy od the schematic if you need it.
Harold
N4HER
”Support Our Troops” - U.S. Army 1963 to 1972
PostPosted: Sep Sun 30, 2012 10:19 am
Hi her50,
Thank you for the link. However, I can't see the full schematic in it. Do you have it available? Thank you
PostPosted: Sep Sun 30, 2012 5:16 pm
VK2FPOL
I looked in the TM and the only full schematic is fig. 8-3 on page 65 of the PDF document. If you need a copy of that send me a PM and when I get a chance I send you a copy.
Harold
N4HER
PostPosted: Nov Fri 16, 2012 6:04 am
I know this is an old post and I may need to post this as a new question but... I just found one of these at an auction and I couldn't pass it up. I'm trying to build some history of it and there's a marking engraved on the side that I can't figure out for the life of me. It says "USA H-6 IMRAA" on the side and on the lid it says "USA HQ-6". I obviously know what the USA stands for and I imagine I can figure out what the HQ-6 means. The IMRAA is what's stumping me. It's not the end of the world if I don't figure it out but it would be nice! The unit's serial # is 37 if that helps or matters. Anyone that has thoughts, clues, suggestions would be great! I have pics if that will help.
73's KD0PAJ
USMC
PostPosted: Oct Thu 22, 2020 2:02 am
I have just inquired a TS-352 multi meter. Is there anyway I could get the pdf manual my email is sweepsjh at the gmail. com
PostPosted: Oct Thu 22, 2020 4:50 am
Does this work for you?
http://www.nj7p.org/Manuals/PDFs/Milita ... 20NJ7P.pdf
PostPosted: Oct Thu 22, 2020 5:02 am
I have them as well if needed.
Steve
Users browsing this forum: John Limbach and 15 guests
cron
