Page 1 of 1
[ 3 posts ] |
Author |
Chris H
Post subject: Chris Ping....TT1A Question Posted: Feb Tue 03, 2004 3:43 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 828 Location: Grand Blanc, MI USA
You should be able to do the grid leakage and shorts test on both plates of the tube--not sure what is causing the problem here--dirty switch--faulty wiring--bad solder joint? Dirty tube socket could also be an issue. Grid leakage test can be tricky, and sometimes requires a selected tube--according to the manual.<P>Same suspects for lower test on G2/P2/K2 setting. You'd have to know that a certain tube tested a certain way on a TT1A to eliminate the tester from the equation.<P>"Ping"--what does that mean?<P>------------------<BR>
Top |
Page 1 of 1
[ 3 posts ] |
