Page 1 of 1
[ 11 posts ] |
Author |
Jim Dutridge
Post subject: Eico 950B Posted: Jul Fri 30, 2004 11:50 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 7485 Location: Toledo, Ohio
Reworking this cap checker and I need to replace a 8 MFD @525v. Seems the highest voltage I can find is 450v. Anybody have a source for a higher working voltage cap? TIA.<P>------------------<BR>Jim
Top |
Norm Leal
Post subject: Eico 950B Posted: Jul Fri 30, 2004 11:55 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 30748 Location: Livermore, CA
Hi Jim<P> AES, <A HREF="http://www.tubesandmore.com" TARGET=_blank>www.tubesandmore.com</A> has 500 volt electrolytic caps. You could series 2 - 16 mfd caps?<P>------------------<BR>Norm
Top |
Lou deGonzague
Post subject: Eico 950B Posted: Jul Sat 31, 2004 2:23 am |
Moderator |
Joined: Jan Thu 01, 1970 1:00 am Posts: 9377 Location: Latham NY 12110
Even 2 22uf in series would be ok. If you use 2 450v units you would probably not even need balancing resistors.<P>------------------<BR>
Top |
cwtravis
Post subject: Eico 950B Posted: Jul Sat 31, 2004 4:46 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2618 Location: Northern Panhandle, WV
Hi Jim,<BR>Mouser has 10uf, 600v caps in stock, but they are not cheap at $11.63 each: <A HREF="http://www.mouser.com/index.cfm?handler=displayproduct&lstdispproductid=265504&e_categoryid=500&e_pcodeid=75002" TARGET=_blank>http://www.mouser.com/index.cfm?handler=displayproduct&lstdispp roductid=265504&e_categoryid=500&e_pcodeid=75002</A> <P>------------------<BR>Carl
Top |
Leigh
Post subject: Eico 950B Posted: Jul Sat 31, 2004 5:05 am |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 31285 Location: Maryland 20709, USA
Leigh wrote: <font>quote:</font><HR>Originally posted by cwtravis:<BR><B>Mouser has 10uf, 600v caps in stock...</B><HR> <P>This would be a much better solution than wiring two caps in series. Definitely the "right" way to do it IMHO.<P>------------------<BR>73 de Leigh W3NLB | | Leigh@AtwaterKent.Info<BR><A HREF="http://www.AtwaterKent.info" TARGET=_blank>http://www.AtwaterKent.info</A> | | <A HREF="http://www.Synchrophase.info" TARGET=_blank>http://www.Synchrophase.info</A>
Top |
Kent Kershaw
Post subject: Eico 950B Posted: Jul Sat 31, 2004 7:05 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 977 Location: Charlotte,NC
Maybe I'm misunderstanding something here. I always thought that unlike resistors, no matter how you wired them together, the max voltage the caps could stand would not change, ie. 2 450V caps = 1 450V cap. Unlike 2 paralleled resistors where 2 half watt = 1 one watt. Or is that 525V cap rating not all that critical here. I have a 950B and used a 600V cap.<P>------------------<BR>
Top |
Leigh
Post subject: Eico 950B Posted: Jul Sat 31, 2004 6:28 pm |
Member |
Hi Kent,<P>No, voltage ratings of capacitors in series are additive. So a pair of caps rated 1000 volts wired in series would yield a 2000 volt rating. This only works for identical capacitors.<P>The idea being that the insulation in the capacitor is not perfect, so there is some leakage current flowing. Thus, you actually have two resistors in series, and the voltage divides equally across the resistors. Thus, the voltage across each individual capacitor is still within ratings.<P>Two caps in parallel would have a voltage rating equal to the lower voltage cap, i.e. a 100-volt in parallel with a 250-volt would be rated 100 volts.<P>However, as mentioned in my previous post, the "proper" replacement is a single cap rated at least 525 volts. The 600 volt cap would be fine.<P>------------------<BR>73 de Leigh W3NLB | | Leigh@AtwaterKent.Info<BR><A HREF="http://www.AtwaterKent.info" TARGET=_blank>http://www.AtwaterKent.info</A> | | <A HREF="http://www.Synchrophase.info" TARGET=_blank>http://www.Synchrophase.info</A>
Top |
Jim Dutridge
Post subject: Eico 950B Posted: Aug Sun 01, 2004 6:28 pm |
Thanks for all the replies. Think I'll go the single cap route.<P>------------------<BR>Jim
Top |
Alan Douglas
Post subject: Eico 950B Posted: Nov Tue 15, 2005 6:54 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 25381 Location: Pocasset, Cape Cod, MA
Yes, but modern mylars are likely to be pretty close. Ideally you'd measure them on another cap meter.<P>Check the voltage pot: they're prone to burnout at the bottom end, when some careless user discharges a large electrolytic into it by turning it down to zero too fast.<BR>------------------<BR>
Top |
Page 1 of 1
[ 11 posts ] |
