It is currently Jan Sat 16, 2021 3:08 am
 Post subject: Intermittent 1822 Frequency counter -looking for schematic
PostPosted: Aug Sat 28, 2004 4:35 am
If this has plug-in circuit boards, try cleaning the edge connectors by rubbing gently with a pencil eraser. Be sure you brush off all of the eraser droppings before you plug the board back in <IMG SRC="http://antiqueradios.com/forums/biggrin.gif"><P>------------------<BR>73 de Leigh W3NLB | | Leigh@AtwaterKent.Info<BR><A HREF="http://www.AtwaterKent.info" TARGET=_blank>http://www.AtwaterKent.info</A> | | <A HREF="http://www.Synchrophase.info" TARGET=_blank>http://www.Synchrophase.info</A>
PostPosted: Aug Sat 28, 2004 11:36 am
What is an 1822? Are we supposed to guess? OK, I say it's a B&K. Or possibly HP, Albia, Global, Tek, Wave Tech, Keithley, Fluke. Am I close?<BR>Actually, by your description, it sounds like you may not have a problem at all. If you are running a signal directly from a generator into the counter, you may not have a high enough amplitude, as some require almost half a volt to read properly. And most generators are not amplitude stable; the output can fluctuate wildly. BTW, if the counter has a switchable 50 ohm input impedance, turn it off.<BR><P>------------------<BR>
PostPosted: Aug Mon 30, 2004 5:41 am
You can order the schematic and parts list on <A HREF="http://WWW.bkmanuals.com" TARGET=_blank>WWW.bkmanuals.com</A> for 6 dollars.<P>Peter<P>------------------<BR>
Users browsing this forum: GF-RADIO, hylaphone, Jiri Placek and 19 guests
