It is currently Jan Tue 19, 2021 3:11 am
 Post subject: 7199 settings/equivalent
PostPosted: Sep Mon 13, 2004 8:24 pm
Just take three new ones and see what they read... OK, but who can afford 'em?<P>If you can translate the base pattern (there are NO others based like the 7199), 6AN8 or 6BL8 should be close. If I had to replace a 7199, I'd rewire for one of those, or get a new Russian one...<BR><P>------------------<BR>
PostPosted: Sep Tue 14, 2004 4:57 am
I don't know about your tester, but my Knight 600 has a switch per pin. Filament pins go down, grid and plate for the section under test go up. Set the tester for 6AN8, then switch the pins that are different: triode is 1 and 9 instead of 1 and 2, pentode is 2,3,7 instead of 6,7,8. Make sense?<P>6AN8: <A HREF="http://hereford.ampr.org/cgi-bin/tube?tube=6AN8A" TARGET=_blank>http://hereford.ampr.org/cgi-bin/tube?tube=6AN8A</A> <BR>7199: <A HREF="http://hereford.ampr.org/cgi-bin/tube?tube=7199" TARGET=_blank>http://hereford.ampr.org/cgi-bin/tube?tube=7199</A> <P>------------------<BR>
PostPosted: Sep Tue 14, 2004 5:40 am
(edited after seeing Tom's second post)<P>I've seen the 6GH8A recommended as a sub for the 7199 in audio applications- socket rewiring is required. I've never tried it.<P>7199: <A HREF="http://tdsl.duncanamps.com/show.php?des=7199" TARGET=_blank>http://tdsl.duncanamps.com/show.php?des=7199</A> <P>6GH8A: <A HREF="http://tdsl.duncanamps.com/show.php?des=6GH8A" TARGET=_blank>http://tdsl.duncanamps.com/show.php?des=6GH8A</A> <P>I have a Conar 223 tester which has 12 levers with 3 positions. I can post its setup for the 7199 and a few other tubes if it will help.<P>-Steve W.<P>------------------<BR>
Users browsing this forum: barrettt, Spivey, Thewasp and 29 guests
