It is currently Mar Mon 25, 2019 4:40 am
Post New Topic Post Reply  [ 38 posts ]  Go to page 1, 2  Next
 Post subject: Restoration of HP141s/8553L/8552A
PostPosted: Jan Tue 15, 2019 7:17 pm
today the HP arrived here.
First inspection: the tuning knob in the 8553L is fixed, not possible to turn that.
 Post subject: Re: Restoration of HP141s/8553L/8552A
PostPosted: Jan Wed 16, 2019 4:04 am
Hello Martin,
Congratulations, It arrived without damage. Looks very nice. You'll be impressed when you have it running properly, they are still impressive machines. SLOW at narrow bandwidths, but impressive nonetheless.
You do have the maintenance manuals, don't you?
Are you looking for the other RF modules?
PostPosted: Jan Wed 16, 2019 9:04 am
hello Mike,
there was no Manuals and no Powercable (but I am happy to have that cable in stock)
Yes, I am looking for some plugins to make it more useful.
btw it looks not so heavy then it is :mrgreen: around 30kg
greetings
Martin
PostPosted: Jan Wed 16, 2019 2:51 pm
Congrats Martin! I was at HP when these were in production.
Sold boat loads of them. Excellent SA's.
The stuck knob issue is very common with these. The shaft
going through the bushing in the panel binds. It takes patience
and some penetrating oil (I use auto tranny fluid) to get
it turning. If you can get that shaft to move even a little,
keep working it back and forth while applying oil. Some
have reported heating the shaft helps too.
There are a couple of fuses buried inside the plug ins.
If these blow take a look at the regulators. If one is bad it'll
take out the other.
Steve
PostPosted: Jan Thu 17, 2019 1:17 am
I dont have the schematic for the 141S but I have been meaning to do this modification to my 141T that blows fuses. Im glad I printed it from the internet because the link is no good today.
Jeff-W3JKO
PostPosted: Jan Thu 17, 2019 9:16 am
thank you
exactly this was helpful, its now free.
greetings
Martin
PostPosted: Jan Thu 17, 2019 8:32 pm
:mrgreen:
PostPosted: Jan Fri 18, 2019 9:02 am
the AC input filterbox with the plug is shortet between pin 1+3
PostPosted: Jan Fri 18, 2019 12:43 pm
If you bypass the power input filter, does the unit operate?
PostPosted: Jan Fri 18, 2019 4:11 pm
If its the type with the sliding plastc window check the 'safety' cap.
I've had three of these fail and usually accompanied by smoke
and flames. These are wired in *before* the fuse.
Nice collection of vintage Tek scopes BTW! Wish I had kept my
545B but space wouldn't allow it.
Steve
PostPosted: Jan Fri 18, 2019 10:23 pm
This Sprague filter box is not to open, I have removed that and insert another plug and a good filter can.
it wakes up :wink:
greetings
Martin
PostPosted: Jan Fri 18, 2019 10:53 pm
KOOL!!
Congratulations, its nice to see it working.
PostPosted: Jan Mon 21, 2019 12:46 pm
The nuvistor in the 141s HV, (HP numbered) is a 7586 or another?
Calibration.
vertical was no problem it goes exactly.
Horizontal:
When I adjust it so that ranges -from - to , are accurate, and I switch him to do the full sweep from zero to 110MHz, it will nott pass the last 5MHz bc. there is the end of the beam. This may be typical when using 141"s" and the "T" do that better?
I`m on the way to buy the 300kHz Plugin also. This unit have a tracker .
greetings
Martin
PostPosted: Jan Mon 21, 2019 1:25 pm
MM, how do you keep that room cool with that very impressive collection of TEK scopes?? lol. Hope you have a cheap source of power out there!
www.bbtvtestequipment.com
PostPosted: Jan Mon 21, 2019 4:36 pm
Barry, I don't think the heat is the problem, its the weight. I'd venture to guess he has TONS of gear there, and the scary part is looks as if it's in the attic. :roll:
PostPosted: Jan Mon 21, 2019 4:48 pm
That’s exactly what went through my mind as I looked at some of Martin's photos this morning!
I’ve seen many other pictures of his collection and know this isn’t even the tip of the iceberg.
On a related note, I have sometimes feared for your basement floor, Mike. :D
73, de Chuck K4CCW
"The question is not what you look at, but what you see." Thoreau
PostPosted: Jan Mon 21, 2019 5:10 pm
I like that display on the S more than the storage scope version. Much sharper. Nice setup.
Pete
PostPosted: Jan Mon 21, 2019 5:24 pm
the s is also a storage :wink:
about 8556: they ask for 200€ I think that is too much for a analog plugin
The 141s found a place on top of the radio bench :)
greetings
Martin
PostPosted: Jan Tue 29, 2019 9:06 am
the next step:
I found in NL a HP 8556A plugin 50+postage, it`s on the way 8)
about the 1A fuses in back from 8552: is 1A to small there? was blown 2 times
PostPosted: Jan Tue 29, 2019 1:08 pm
Congratulations on your "new" Plut-in!!! It will give you a whole new spectrum to play with. :wink:
As for THE FUSE problem, I had that problem and some how "fixed" it, but I'm sure there are better solutions. I have forgotten the exact problem with that power supply circuit, but if you study the circuit around that fuse I'm sure you'll find the problem. As I remember it was something to do with the initial power up "turn on" conditions in the circuit.
I may have taken some notes, I'll look and see if I have them, and will let you know if I find anything.
Users browsing this forum: Koby, mbruvry, TechyMechy and 11 guests
