It is currently Mar Tue 26, 2019 2:55 am
 Post subject: HP 5345a -5355a -5356a opinion??
PostPosted: Feb Tue 12, 2019 12:44 am
I'm thinking of upgrading my counter setup and I am looking a the 8355A with a 18GHz converter... are these reliable counters, any quirks or weaknesses?
 Post subject: Re: HP 5345a - 5355a -5356a opinion??
PostPosted: Feb Tue 12, 2019 1:43 am
Peter Bertini wrote:
I'm thinking of upgrading my counter setup and I am looking a the 5355A with a 18GHz converter... are these reliable counters, any quirks or weaknesses?
Do you mean 5345A?
As for me, I've got an HP 5350B Microwave counter and love it - overkill for 90% of what I do, but should I need it....My 5345A has no plug-in....
The price was right - the 5350B and a 1742A scope for $60... The scope has yet to earn a spot on the bench - my Kikusui is so much better at everything.
Brian
PostPosted: Feb Tue 12, 2019 2:03 am
this what happens when typing on a lap top in the dark
I was curious if that model has known problems or if there are issues with NLA parts that are failure prone.
 Post subject: Re: HP 5345a -5355a -5356a opinion??
PostPosted: Feb Tue 12, 2019 2:23 am
I have an HP 5347A 20 GHz counter. It has a built in power meter, but I do not have the power sensor, so can't speak to that function, but the counter side of things are pretty good.
PostPosted: Feb Tue 12, 2019 3:35 am
Well, there are some HP-custom amps in the input circuits. If they go, the only option is a donor unit or one of the $$$$ NOS ones. Other than that, ECL logic, mixed with TTL throughout. The +/- voltage regulators are older Motorola TO-66 units with 10pins - MC1463/MC1563 and MC1469/MC1569. Not hard to find, but pricey.
We had the 5345A as a standard for testing period and some frequency use in Navy labs. For higher frequency stuff, we went with measuring receivers - 8902A with all the bells and whistles.
Only failures we saw were the slide switches on the front - the little switch actuators became brittle and would snap off. Again, a donor unit. Electrically, they are a power drain in the off/stby mode - the crystal oven runs 24/7.
Heck, my 5350B, younger than the 5345A has more "hens teeth" parts. HP ran several years with short support cycles - then HP/Agilent went to board-level only on most instruments, with component level almost completely phased out.
Brian
PostPosted: Feb Tue 12, 2019 3:21 pm
Is the 5345A a reciprocal counter? Fast updates? Also looking at the 5342A. Hard choices.
PostPosted: Feb Tue 12, 2019 6:19 pm
I dunno - it has a variable sample rate control, and variable gate time, and does period measurements....
Data Sheet - https://www.keysight.com/main/redirecto ... =EDITORIAL
and it's also listed in most late-70s and 1980s HP Catalogs. The manual is on BAMA. http://bama.edebris.com/download/hp/5345a/5345a_6.pdf
Brian
Users browsing this forum: breadbox, Peter Bertini and 13 guests
