It is currently Mar Sat 23, 2019 11:22 am
 Post subject: Good quality alligator clips
PostPosted: Feb Wed 13, 2019 9:57 am
Does anyone have a source for good quality alligator clips with an insulated covering that doesn't slip every time you try to open the clip?
-Carlos
 Post subject: Re: Good quality alligator clips
PostPosted: Feb Wed 13, 2019 10:11 am
Your frustration is undoubtedly with the Chinese variety of alligator clip that has a dubiously functional silicone insulated sleeve. Not the best of choices for an insulator, as you have discovered.
You might try looking on eBay for genuine Mueller clips with original sleeves; or, you can try dipping the Asian sleeves in alcohol or acetone and let them dry.
PostPosted: Feb Wed 13, 2019 10:36 am
Yeah.... most are cheap crap that the ends aren't even soldered... some are but most not.
Har to find REAL high quality soft rubber flexible type like in the 50-60s
PostPosted: Feb Wed 13, 2019 10:51 am
My first set of clips were purchased from radio shack about 15 years ago and those were still good stuff. I wonder where they sourced theirs.
-Carlos
PostPosted: Feb Wed 13, 2019 12:39 pm
Mueller Electric Co.
18.0" (457.20mm) Alligator Clip, Insulated To Alligator Clip, Insulated Test Lead 300V Multiple Colors.
Ten leads $7.00
https://www.digikey.com/product-detail/ ... -ND/304405
Five (same PVC) 12" for a fiver!
Digikey search results - Pomona + Mueller (test leads).
https://www.digikey.com/products/en/tes ... ageSize=25
Mueller. Roll-your-own. Lol
https://muellerelectric.com/product-cat ... nsulators/
Edit: Mueller threaded barrels...
viewtopic.php?p=2924606#p2924606
PostPosted: Feb Wed 13, 2019 2:49 pm
I ONLY use Mueller copper clips, no steel. They don't seem to make zinc plated copper. Maybe they never did?
PostPosted: Feb Wed 13, 2019 3:53 pm
I have plenty of older jumpers that are in decent condition, but they are terrible at making a decent connection. Some look plated and others appear to be stainless steel. I am in the market for some high quality new jumpers.
PostPosted: Feb Wed 13, 2019 4:47 pm
Do you mean slips out of your grip or the gator slips out of its insulation?
I find the cheapo ones slip out of their own insulation, particularly the smaller ones, and I often have to push it back on after I get the gator clipped, particularly in tight spots where the insulation needs to be right up to the tip.
My Muellers don't usually do that, or at least not as badly.
PostPosted: Feb Wed 13, 2019 4:49 pm
[quote="egg"]Mueller Electric Co.
Ten leads $7.00
Indistinguishable from the cheap Chinee sets. Looks pretty slippery to me. I wonder if, like everyone else, Mueller has gone bottom dollar and making these things in China at the same factory as the cheapo sets.. selling exactly the same cheapo sets under their label. Mueller used to mold their name into the insulated grip, but I see no evidence of this in that photo or the photos on Mueller's site (including the datasheet pdf). Nor do they say those are made in the USA. In fact, I can't find anywhere on their site where they say their stuff is Made in the USA. They used to proudly advertise that.
https://muellerelectric.com/product-cat ... tl/page/2/
PostPosted: Feb Wed 13, 2019 5:07 pm
Mueller still makes the good clip leads. They're just ten times the price of the cheapies that they also sell. At least the cheap sets have PVC insulators rather than silicone.
Here's the good ones, about $6 each:
https://muellerelectric.com/product/bu-3030-a-12-0/
https://muellerelectric.com/product/bu-3131-a-12-0/
The cheap ones are about $7 for a set of ten:
https://muellerelectric.com/wp-content/ ... -00287.pdf
PostPosted: Feb Wed 13, 2019 6:24 pm
Both!
I spoke with a representative through the mueller online chat and they told me that the clip lead set pictured above is not manufactured by them. Most of the alligator clips on their site are stamped mueller on the metal. Might be the same for the boot. I asked about the quality of that set and he said that they have not had complaints. I requested a sample and I am currently waiting to hear back from him but he said they usually only do that for companies.
-Carlos
PostPosted: Feb Wed 13, 2019 6:25 pm
Mueller still sells individual copper clips and insulated covers. You could cut the imported junk clips off your old wires and install the Muellers. Digikey carries them, as does Mouser.
PostPosted: Feb Wed 13, 2019 6:27 pm
Honestly the problem is the wires are the worst part on the cheap ones! Literally about one or two hairs worth of wire inside. I would say it's better to buy the clips and wire and put them together at home. Let's see what they say about that set above though. If they back it up I wanna think that theyre at least a little better than the more common ones. I'm thinking the ones I bought at radio shack that i liked were also PVC. As long as they don't slip I'm happy.
-Carlos
PostPosted: Feb Wed 13, 2019 6:31 pm
If you want highest quality patch cords and probes that are U.S. made go here :
https://probemaster.com/
Respectfully Submitted,
Be_Zero_Be
You never used to be older.
PostPosted: Feb Wed 13, 2019 7:03 pm
Pomona makes excellent quality clip sets too, but be prepared for sticker shock :shock:.
PostPosted: Feb Wed 13, 2019 7:20 pm
Mine are all at least 30 years old. All Pomona, and slide over a banana and, yes... pricey for new ones.
Nice to be able just pop one on a banana jumper when you need it though.
Steve Johnson
https://stevenjohnson.com - Steve's Antique Technology
PostPosted: Feb Thu 14, 2019 1:25 am
I have the best luck with solid copper alligator clips. I once made a test cable for a Eico 460 O'scope, copper for the "hot" lead and tinned for the ground lead.
When I shorted them together, the trace would shift, due to thermal electric effect, I guess.
Charlie
PostPosted: Feb Thu 14, 2019 5:15 am
If you're going to go the "extra mile" and use good clips, you should also use the best wire as well. This is flexible, rubber insulated, 3KV insulated test lead wire.
PostPosted: Feb Thu 14, 2019 2:18 pm
powerwerx also has excellent 5KV Test Lead wire available in rolls of 25' or so
I have used a ton of it, Pomona also makes Premium Silicone Test lead wire in 25' Lengths - I think Zoro Tools on eBay carries it - this is the nicest test lead wire there is, but it is high.
Realistic DX-100/120/150/150a/150b/160/200/300/302/394 Radios
VTVM's & Test gear
PostPosted: Feb Thu 14, 2019 5:31 pm
Your description got me curious, and I looked at the store's description/listing/price, where I bought it, and Spectrum's price is $4+ per 100' cheaper than powerex. Then I checked Zoro on the bay, and they were $60 per hundred feet for the same stuff.
I never buy wire in short lengths, it costs considerably more per foot, and even at 100 feet lots its not very cheap. I usually try to buy 500 to 1,000 feet at a time, often finding surplus or close outs. If you are making cables, you need several different gauges and often quite a few feet of each.
I ordered another 50 Meuller(?) BU-60 clips from Digikey, along with red and black boots. Went looking for some, and I'm out!!
From Allspectrum.com;
Test Lead Wire, EPDM Rubber, 18AWG, MIL-W-13169, BLACK, 100ft spool
Model # CONWIRE-1007-0
Manufacturer Model # 1007-0 $28.99
Click to enlarge
Availability
Stock: 3
Test Lead Wire, EPDM Rubber, 18AWG, BLACK, 100ft spool.
Color: Black
MIL-W-13169
Insulation thickness: 0.045"
NOM O.D.: 0.140"
Working voltage: 5,000
Breakdown voltage: 20,000
