It is currently Jul Fri 19, 2019 9:44 pm
 Post subject: 8445B HP tracking preselector question?
PostPosted: Jun Sun 09, 2019 11:26 pm
Does the digital display track the frequency on the lowest range? Manual only states that the YIG filter is used on the higher ranges--but it is not clear whether the tuning voltage controls the frequency display when the YIG filter is bypassed on the bottom range.
Pete
 Post subject: Re: 8445B HP tracking preselector question?
PostPosted: Jun Sun 16, 2019 11:40 pm
Made the interface cable for the 8445B to 141T. It also shows center tuned frequency on the 0-1500 MHz lowest range. This is a solution for 8555A RF heads that have failed dial drive belts--which are almost impossible to find parts for. Works for most ranges--except those requiring the external microwave mixers.
