It is currently Oct Sat 19, 2019 4:13 pm
 Post subject: Help with Eico 666
PostPosted: Jun Wed 12, 2019 10:53 am
I picked up a nice looking 666, but cant set the line voltage.
Depressing the test button results in only a small movement of the needle.
I do have -65 VDC at the rectifier.
Thanks for any help.
Collecting audio gear and radios because I couldn't afford to buy it when I should have.
 Post subject: Re: Help with Eico 666
PostPosted: Jun Wed 12, 2019 11:56 am
You need to first replace the two electrolytics: C2 10uf 25 volt and C1 10uf 150 volt.
Check all the resistors, especially R19 270K, R5 129 ohm, R6 50 ohm, R2 680 ohm and R3 200k.
If this doesn't help then you may have some dirty controls/switches.
PostPosted: Jun Wed 12, 2019 1:21 pm
The manual for the 666 is available on BAMA here : http://bama.edebris.com/manuals/eico/666/
Read the section on how the LINE ADJ works ... it's on page 5. That may help you narrow it down. As mentioned, definitely replace the electrolytic capacitors before you do anything else. There aren't all that many components in this tester, so it would not hurt to check the resistors as well, and even the potentiometers. There are also a few diodes you can check, including one in the leakage circuit that may be affecting the line set.
It's likely that you've got some dirty switch contacts or potentiometers in a tester this age. Also possible that the meter is bad, but there are other ways to check that. DO NOT use your ohmmeter to check the meter movement. See other threads on this forum or my website below for how to do this safely.
PostPosted: Jun Wed 12, 2019 5:17 pm
It looks like someone has already replaced the C1 (10/150) with a 10/450.
I'll check R19 and R8 as these are the only resistor in the Line Test circuit.
I'll then check the meter. I have found and read the instructions on how to do this.
I don't want to waste my time changing out pars if the meter is shot.
http://www.oldtubes.net/library/test_equipment/reeland_eico_scans/EICO_666_TRACINGS_3.png
Joe Y
PostPosted: Jun Wed 12, 2019 9:11 pm
I think the adjustment pots are also know to go bad. It's a simple tester and unless the transformer or meter is bad, usually an easy fix.
PostPosted: Jun Thu 13, 2019 12:06 am
Yes, the cal pots can have the Tin Whisker problem and need to be taken apart and cleaned or replaced. Also since it was a kit you need to go over every solder connection for poor workmanship.
PostPosted: Jun Fri 14, 2019 3:48 am
Good news:
The meter checks out fine.
Next, I'll try to disassemble and clean the adjustment pots.
Users browsing this forum: Don_S and 4 guests
