It is currently Jul Tue 23, 2019 12:23 am
 Post subject: Triplett test leads (Reverse banana) & Simpson compatible?
PostPosted: Jun Thu 13, 2019 9:17 pm
I just picked up a Triplett 630 Type 5 (new model) with reverse banana leads. I see some on E*pay, but it describes them for Simpson. Will the Simpson leads interchange with the Triplett. If this has been discussed before, my apologies.
 Post subject: Re: Triplett test leads (Reverse banana) & Simpson compatibl
PostPosted: Jun Fri 14, 2019 12:05 am
The reverse banana leads are supposed to be "industry standard" size, but something nagging at me recalls two different sizes, small and large. Not sure, but if you google them and only one size pops up, there ya go.
Manual for the Triplett and the Simpson should specify the size of the test lead plugs ....
www.bbtvtestequipment.com
PostPosted: Jun Fri 14, 2019 5:26 am
I have a model 60 that came with those miserable reverse bananas. I replaced them with 5-way binging posts with the screw-on insulated cap removed. They were just the right length for the case and almost look original. I don't know whether or not this will work with other models.
RRM
PostPosted: Jun Sat 15, 2019 2:58 am
They are supposedly protecting us from ourselves, but are putting us at risk when we are forced to connive ways to circumvent these bastard jacks. With my lathe, I bore holes, part way, into brass spacers, to fit the banana plugs and solder leads into the small opposite end.
Charlie
PostPosted: Jun Sat 15, 2019 4:01 am
Busted out my Simpson 260 8P test leads for this..
OD. .322
ID. .178
Thickness (wall). .067
I love the meter but hate the lead options. That's why I also bought the 260 6P as well.
Oldaker makes Simpson compatible leads and possibly Probe Master. Give them a call for fitment options for your meter to be sure.
PostPosted: Jun Sat 15, 2019 4:20 am
Your memory is perfectly fine. They are not the same size. I tried a test lead extension barrel and it would not fit over the pin on the meter jack.
PostPosted: Jun Sat 15, 2019 7:39 am
I placed an order with Probe Master. They claim to be USA made. Thanks for the info. everyone.
Users browsing this forum: Superretrodyne and 12 guests
