It is currently Jul Wed 17, 2019 3:42 am
 Post subject: HP 3314A repair notes
PostPosted: Jun Fri 14, 2019 10:11 pm
Just had to repair a faithful HP 3314A. It was throwing E30, E31 and E34 errors on start up and during ranging. Looks like it was bad connections on the A1 board to the connectors going off of it, corrected by unhooking the ribbon cable, flex connector cable and signal connectors then extracting the board off the two connector that penetrate the board, J3 and J8. Errors went away on reassembly.
Since there are a number of loops, DACs and 2 custom ICs U101 and U502, I went through and made some troubleshooting notes and waveforms. Note I set the O/P for triangle out at 1 kHz 1 V since the native waveform is a triangle.
Note that the two troubleshooting flow charts are useful for more than CAL errors, the U101 DAC verification procedure works like a charm since the DACs two complimentary O/Ps are current waveforms, the verification is a simple way to test U101.
HP 3314A Troubleshooting 1.pdf [247.4 KiB]
Downloaded 20 times
HP 3314A Troubleshooting 2.pdf [280.32 KiB]
Downloaded 6 times
HP 3314A Troubleshooting 3.pdf [358.2 KiB]
Downloaded 4 times
HP 3314A Troubleshooting 4.pdf [299.03 KiB]
Downloaded 5 times
HP 3314A Troubleshooting 5.pdf [298.87 KiB]
Downloaded 5 times
HP 3314A troubleshooting 6.pdf [48.8 KiB]
Downloaded 6 times
 Post subject: Re: HP 3314A repair notes
PostPosted: Jun Sun 16, 2019 4:29 am
Recently my 3456A failed. I opened it and found that all I had to do was reseat one of the boards. I guess that's a common thing. Immediately thereafter my HP bench DMM failed on one digit. I did the same and it's good to go now.
Users browsing this forum: Jthorusen and 8 guests
