It is currently Feb Sun 28, 2021 11:36 am
 Post subject: HP3490A bench multimeter
PostPosted: Sep Sun 22, 2019 6:03 am
Hi all - there's currently an HP3490A bench multimeter on our local auction website for NZ$200, say US$150, opening bid - it looks to be in good condition with the big operators manual. It doesn't appear to be connected to anything but the display says "12. 0000" and it's set to "Auto" and "Ohms". Is it worth a gamble? I have asked if there's any cal label but no answer yet.TIA.
https://www.trademe.co.nz/electronics-p ... 2df23c-005
Cheers - Martin ZL2MC
 Post subject: Re: HP3490A bench multimeter
PostPosted: Sep Sun 22, 2019 11:40 am
Don't you mean 12000.3
How on earth are you going to get that 20lb monster past the wife?
https://www.youtube.com/watch?v=ZPr3CsSHJuY
Boys and their toys... :)
PostPosted: Sep Sun 22, 2019 12:53 pm
I "NEED" one of those, that is beautiful.
PostPosted: Sep Sun 22, 2019 1:15 pm
What do you want it for? Do you really need a 6-digit bench DMM? Given its age, it probably isn't going to give you six digits worth of accuracy. Even if it was calibrated recently, it probably would not hold very long. That's the usual reason labs get rid of instruments like this. If you really need six digit accuracy, a new(er) meter should be considered.
As a collectible, it's not necessary to rationalize; if you want it, and it's not going to put you out money-wise or family-wise, go for it. It looks to be in excellent condition and the seller appears to be quite reasonable about picking it up in person and knowledgeable about its condition. The manual is worth something too if you are going to own the meter.
PostPosted: Sep Sun 22, 2019 1:59 pm
The HP 3490A,
A Five-Digit Multimeter, That Can Test Itself !
Halfway down page. http://hpmemoryproject.org/wb_pages/wall_b_page_14b.htm
PostPosted: Sep Mon 23, 2019 8:56 pm
Make sure you ask if you have the option to return with in a 30-day return.
HP Makes several quality Products. So as it shows to be functioning as demonstrated and it doesn't show any damage, I would take it in a heartbeat if I didn't have my Flukes and HP's. Very nice on the buttons and switch, ask if it has an internal functioning pass test that shows no errors in a photo.
Best of luck, Looks good to me.
Visit our site:
I was smokinradios Long time ago (2004)
PostPosted: Sep Mon 23, 2019 9:42 pm
Agreed. After a large mug of coffee and a comfy chair, common sense prevailed. I phoned an old friend and he said "anytime you want to measure something to greater accuracy or resolution than your Fluke 77, then I've got an HP 3458A here you can borrow."
Problem solved.
PostPosted: Sep Mon 23, 2019 9:54 pm
Too much money. You should be able to get a 3456A for that money in working condition. I don't know how Trademe works, but up here, you can return anything for any reason from Ebay. I don't think the manual adds much unless you plan on servicing it. Nearly all the HP manuals are available for download right from Agilent.
PostPosted: Sep Mon 23, 2019 11:02 pm
I'd wait for a 12 digit one ........ :-D. 8)
PostPosted: Sep Tue 24, 2019 5:19 pm
It's an impressive show piece but otherwise a waste of money. The chances that it operates properly are slim. For the price there are many more practical DMM's. A six digit display can almost guarantee problems, if not now, then in the near future.
Pete AI2V
"It's always darkest before it's pitch black"
PostPosted: Sep Tue 24, 2019 11:55 pm
These were HPs first reasonably modern (contains ICs) bench multimeter. They use a whole bunch of proprietary HP 16-bit ROM chips which have a tendency to fail. It is very complex and hard to work on. I would recommend that if you were to buy a vintage HP bench multimeter, you should consider the 3455A. It was HPs first microprocessor controlled meter and is a real beauty of 70's engineering. The only major trouble spot with it is the capacitors on the 5V rail, but that is an easy fix. If you want a reasonably modern 6.5 digit meter, get the HP 34401A. It is the absolute #1 industry standard meter and was only very recently discontinued (over the loud objections of engineers everywhere, mind you!)
-Matthew
If it ain't broken, you’re not trying hard enough...
PostPosted: Sep Wed 25, 2019 11:59 am
i don`t know this HP, but it was comm for 5 1/2 digit oldies to have the overflow at 199 999 or some models like the Fluke 8300A at 119 999, so I think it is this, allready , Resistor open = 1200000 kOhms > overflow.
The size is living room compatibe 19 inch rackmount, 10kg are also common for the time.
nice instrument 8)
Died ROMs can be swapped with a adaptor socket to eproms..
Voltnuts can sale the car to buy a Fluke 8508 or like that, it have a aged LTZ1000 and is very trustful.
Martin
PostPosted: Sep Wed 25, 2019 3:56 pm
I own an HP 3456A. It was a lucky find on epay. $30 for the meter itself, $40 for shipping. It arrived in almost-working condition. Now it works perfectly after replacing 2 electrolytic capacitors in its power supply. But I don’t use it every day. For many routine tasks a generic 3.5 digit multimeter is more than good enough.
I do recommend taking the advice given by our fellow ARF members who have (or had) careers that exposed them to a bunch of lab-grade test gear. Their many years of hands-on experience is quite valuable.
Also when doing research on test gear, I recommend the “Test Equpment” and “Metrology” forums at:
http://www.eevblog.com/forum/index.php
-EB
Users browsing this forum: bob1951 and 27 guests
