It is currently Oct Fri 22, 2021 2:30 am
Post New Topic Post Reply  [ 70 posts ]  Go to page Previous  1, 2, 3, 4
 Post subject: Re: Restoring an RCA WV-98C Senior VoltOhmyst VTVM
PostPosted: Dec Thu 17, 2020 2:59 am
Update #10
I’ve finished calibrating the run K114 unit.
Click the image for a full-size view.
It meets its specs, but the 150, 500, and 1500 volt ranges were pretty close to the edge, and the AC zero and 50 volt range calibration were a little flakey. But after a couple of rounds of calibration and checking the lower ranges it seemed to settle in. I’ve put it on the bench to use as the main VTVM for a while, to see if the calibration is going to drift.
I’m reminded of the troubles that Calambres had with his RetexKit VV-1 VTVM (a Spanish clone of the Heathkit IM-11 VTVM). His upper AC ranges were also inaccurate. He solved the problem by replacing the 6AL5. I should give that a try.
PostPosted: Dec Thu 17, 2020 8:28 am
Steve;
Your work is always such a pleasure to follow.
Ex: Same job, same building, same phone #; 4 Corp's: RCA, GE, Martin, Lockheed-Martin: 48+yrs '14
PostPosted: Dec Thu 17, 2020 12:36 pm
Steve, back when I was building kit VTVM's for myself and several others, they all came with what was called, in various ways, "special factory aged tubes". So I can well believe the tubes might make a difference in the instruments today. I think they were aged as in burned in to minimize drift, but also probably selected for matched sections in each tube. Who knows. Makes some sense though.
PostPosted: Dec Thu 17, 2020 1:47 pm
Barry H Bennett wrote:
...I think they were aged as in burned in to minimize drift, but also probably selected for matched sections in each tube. Who knows. Makes some sense though.
Barry, I have always been under that assumption for what it's worth. I have read several times that tubes that have similar (or identical if you are lucky) sections work the best.
PostPosted: Dec Sat 19, 2020 7:29 pm
Do you have a list of the resistors you used to replace the out of tolerance resistors?
Also on my WV-98C (VIZ version) someone installed a D cell holder and wired the negative to the chassis. Not sure if grounding the - to the case was a later manufacturing change or if someone just did it wrong. I may just pull the battery since I use a DMM for ohms measurements.
PostPosted: Dec Sun 20, 2020 5:48 am
No, I have a large stock of precision resistors and used whatever I had that was the right value.
I buy mostly from Mouser but also from DigiKey. I try to stock Vishay/Dale CC60 resistors when I can, but Mouser doesn't stock every value, and Vishay doesn't make them larger than 1 Megohm. For the higher values, I use Vishay/BC Components HVR37 and VR37 series resistors. I'll use KOA/Speer MF1/2 series resistors if I can't get the others, or KOA/Speer MFS1/2 series if I can't get the larger MF1/2 ones, or at last resort Xicons or whatever else is available in the value I need.
According to the schematic, if the negative end of the battery is grounded, the function switch will short the battery on the AC, DC+, and DC- function settings.
PostPosted: Dec Sun 20, 2020 5:51 am
Maybe I looked at it wrong.
Or someone could have modded it at some point?
PostPosted: Jan Fri 08, 2021 7:43 am
Hello Steve,
I do the same far as my resistors go but it seems like Dale brand is getting harder to buy.
PostPosted: Sep Thu 16, 2021 1:24 am
I have heard that some people put back-to-back 1N4001 diodes across the meter movement. Is this advisable?
PostPosted: Sep Thu 16, 2021 4:58 am
I don’t think it’s needed. The VTVM circuit inherently limits the voltage that can be applied across the meter and its series resistor.
Users browsing this forum: kdanner and 24 guests
