It is currently Nov Tue 24, 2020 2:15 am
 Post subject: Strange clamp
PostPosted: Oct Thu 15, 2020 12:36 am
Strange clamp 10-14-2020 2 sm .jpg[/attachment]I found this strange C clamp at a Hamfest (that's the radio connection). The handle rotates only about 45 degrees allowing the shaft to slide up and down. Turning the shaft back locks it, but does not put any pressure on anything clamped in it. Can anyone tell me what it is for? CharlesD
 Post subject: Re: Strange clamp
PostPosted: Oct Thu 15, 2020 12:41 am
It "looks" as if it is a quick release C-clamp. There should be a threaded collar between the shaft and the clamp body. The shaft should rotate 90" CCW, then lock against the threaded sleeve allowing it to loosen the clamp. The the clamp should slide in against the clamped part, rotate 90'CW and then start turning the threaded sleeve to tighten. I'd say your threaded sleeve is rusted and not turning.
PostPosted: Oct Thu 15, 2020 12:53 am
Apparently it's intended to clamp something that is compressible.
PostPosted: Oct Thu 15, 2020 1:49 am
In my neck of the woods they are known as G-cramps... as old as the hills.
PostPosted: Oct Thu 15, 2020 4:04 am
Right, quick release would be handy in a production setting. It's a keeper.
Here are some standard C-clamps. The rusty ones I inherited, almost never use but will not sell. Modern bar or pipe clamps are quicker to clamp and release and have a much wider range.
Burl Ives, RIP, oldtimer.
[:l>)
PostPosted: Oct Thu 15, 2020 12:28 pm
Worth soaking in EvapOrust, or even vinegar. They are pretty nice clamps when working properly
PostPosted: Oct Thu 15, 2020 4:25 pm
You can never have too many clamps,
PostPosted: Oct Sat 17, 2020 3:24 am
So true. I always seem to have one fewer clamp than I need.
PostPosted: Oct Sun 18, 2020 9:13 pm
Barry H Bennett wrote:
Worth soaking in EvapOrust, or even vinegar....
+1 Over the years I've run into several quite rusty G-clamps... they've all cleaned up well with just oil and rubbing the rust off. They all work fine. The cleaned-off rust leaves a "browned metal", a bit like the old gun barrel finishes.
Cheers,
Roger
Roger Jones,
Thornhill, Ontario
PostPosted: Oct Thu 22, 2020 1:20 am
Many thanks to all who offered suggestions for my rusted clamp. Is indeed a G clamp, with the threaded collar well rusted in place. I've tried soaking in vinegar for three days, and using Blaster at the threads. So far, no luck. I'll keep trying. CharlesD
PostPosted: Oct Thu 22, 2020 5:55 pm
might have to use a little heat. Dry it out, and with a heat gun on high warm up the outside of the threaded part while trying to exercise the screw. Might need to put the whole clamp in a vise, and use a vice grip or other kind of "handle" to get a little more leverage. You're not trying to make it do a full turn... just break loose enough so the rust solvent will work once it cools down a bit.
I've seen folks (like me) use a torch and get the outside red hot.... but that's a last resort. It usually works, but occasionally results in a puddle of metal on the floor. :-D. Not entirely by accident.............although if it's cast, it may melt when least expected.
PostPosted: Oct Thu 22, 2020 7:10 pm
Try soaking the frozen section in Kroil for a few days. Good chance it will loosen right up.
PostPosted: Oct Thu 22, 2020 9:13 pm
To me it looks like a clamp that can be positioned deeper or less deep very quickly.
Instead of having to turn the treads many times for several inches or more, it looks like you turn just a single tun or so to loosen it, then twist the threaded area to the side and slide the shaft to the next needed position.
PostPosted: Oct Thu 22, 2020 11:40 pm
CharlesD wrote:
... the threaded collar well rusted in place. I've tried soaking in vinegar for three days, and using Blaster at the threads. So far, no luck. I'll keep trying. CharlesD
WD-40?
Cheers,
Roger
Roger Jones,
Thornhill, Ontario
PostPosted: Oct Thu 22, 2020 11:57 pm
I might have missed it.. if the teeth are offset or depends on teeth size/angle. this could be used to apply a certain amount of toque by slipping, no? i could see that. - like a clutch
Users browsing this forum: Google [Bot] and 16 guests
