It is currently Nov Tue 24, 2020 2:52 am
 Post subject: Westmore 501 / Triplett 3444 HK Shorts Test
PostPosted: Oct Tue 20, 2020 12:40 am
Reading the manual it states, "if a filament type tube is being tested, the meter will indicate full scale deflection when the switch is in the H-K position. (No indication indicates open filament)."
Does this mean that every tube tested should show full scale deflection at this setting? Mine does not, I imagine it shows H-K leakage? Is this correct?
I am testing 6L6GC tubes.
Doesn't make sense to me so thought I'd ask before I tear into this tester.
Thanks, Mauro
 Post subject: Re: Westmore 501 / Triplett 3444 HK Shorts Test
PostPosted: Oct Tue 20, 2020 12:55 am
No, only filament type tubes. ie. Tubes where the filament acts as the cathode.
DM
PostPosted: Oct Tue 20, 2020 12:57 am
Ahh, makes sense but I wonder why they wouldnt state that?
Thank you.
Users browsing this forum: Jimmie Stewart, John Limbach, PhilF and 12 guests
