It is currently Oct Sat 23, 2021 4:06 pm
 Post subject: Eico 666
PostPosted: Sep Thu 16, 2021 2:26 am
Got my first tube tester. It's in ok condition. The Grid pot, a linear 5k, 5W, 5% with a spst gained switch on the back, the pot is open and looks to have very fine (1/10 hair size wire) wire hanging in there. It did not have the lamp mod like suggested online, that I found at fourwaters. Also, to make things worse someone 'spun' the set screw on the aluminum pot shaft and made it very difficult to get off. I thought it was corroded, nope just aluminum all gulled up.
Anyone have suggestions on the 5k pot? Sounds like it is a common or potential problem with this unit. Going to see if fourwaters has the 20% 5k pot. I can find 5k, 5w 10% with no spst.
File comment: Can't believe someone ground this open.
File comment: Gray very fine wires, you might be able to see the broken wire on left.
File comment: This looks like 5 separate windings to me? Must be for its linear function calibration?
only the dead fish go with the flow
 Post subject: Re: Eico 666
PostPosted: Sep Fri 17, 2021 2:20 am
The multiple different windings is not really a linear device? More like a stepped linear pot? This is designed to the circuit, or the circuit around it?
PostPosted: Sep Fri 17, 2021 1:42 pm
I have one, PM me.
PostPosted: Sep Fri 17, 2021 11:18 pm
Sent, thank you sir!
PostPosted: Sep Sun 26, 2021 9:36 pm
Anyone know what is the correct color for the case? My unit was repainted and is a blueish gray? thks
PostPosted: Sep Tue 28, 2021 2:33 am
From what i can see of the inside of the case the color looks close , a better photo would help .
These on eBay is the original color .
https://www.ebay.com/itm/144104116639?h ... SwkG1g5KZo
https://www.ebay.com/itm/144214242543?h ... SweLNhS9Uw
Mark
PostPosted: Sep Wed 29, 2021 12:00 am
Thanks for the references. From looking at those on ebay, they look blue gray. The insides of mine look more gray. I did pick up a smoke gray spray bomb and that's to gray. So hard to compare colors w/o the unit or a chip in hand.
Users browsing this forum: calmark, drworry, pauls.ironhorse and 26 guests
