Hp 3400a meter scale
Discussion of test equipment, tools, and related topics. Using, finding, fixing radio and television test equipment. Ads are not permitted.
Post Reply
devildog63
Sep Sun 11, 2016 4:39 pm
Carrollton GA 30116
Post by devildog63 »
Hp 3400a meter scale peeling. It's not bad, none of the lines are affected but I know it's a matter of time. I have hears of scanning and printing a new one. Is there a better way ?
KM4YTW
devildog63
Carrollton GA 30116
Re: Hp 3400a meter scale
Here's a picture.
KM4YTW
Barry H Bennett
Nov Wed 30, 2016 6:35 pm
Sunbury, Ohio 43074
Contact:
Post by Barry H Bennett »
You could try clear coating what’s left. It should preserve it. You’d have to remove the scale to do this safely
devildog63
Carrollton GA 30116
Thanks Barry. I'm thinking something like that too. I may acan it first in case the clear coat doesn't work out. I was wondering if the clear coat would have static build up ? I know one guy that cleaned the meter glass and his needle would jump all over the place. One thing for sure it's not gonna last much longer unless I do something.
KM4YTW
stevebyan
May Wed 18, 2011 1:40 am
Littleton, MA
Contact:
Post by stevebyan »
I have a number of HP meters that I plan to coat with a spray of clear lacquer, after I scan them as a backup. I plan to use Microscale Industries Micro-Mask masking fluid on the mirror, rather than removing it from the meter card.
https://www.microscale.com/Merchant2/me ... de=FINPROD" -="window.open(this.href);return false;
If you try this, let us know how it turns out. I won’t be in a position to do it myself for another couple of months, as I’m recovering from hand surgery.
I noticed something when scanning the card for my HP 413A Null Meter. I left the card under the heavy lid of my scanner for several days. When I removed it, all the lifted pieces of emulsion had flattened back down. They stayed that way for months. So, put your meter card face-down on a pane of glass, stack some heavy books on top of it, and leave it that way for several days before you give it a coat of clear lacquer.
Barry H Bennett
Sunbury, Ohio 43074
Contact:
You can control static by wiping the glass, or plastic, with a dryer sheet. Lasts a long time.
ttx450cap
May Sun 10, 2020 1:55 pm
Lake Charter Township, MI
Post by ttx450cap »
Someone suggested that in my ghost meter phenomenon thread. My tripleet meter is still working well after a year or more? I did not use dryer sheets, just cleaned the surface with windex or alc. dont rem.. dont have dryer sheets around here.
devildog63
Carrollton GA 30116
Thanks fir sll the info. Barry I'll try your idea , if it works I may take some kind of adhesive with a toothpick and go around all the edges since it looks like it's peeling from the edges. Get them sealed up may make it last a while longer.
KM4YTW
gabbyhayes
Jul Sun 26, 2020 4:27 pm
Yorkton/SK/Canada
Post by gabbyhayes »
Barry H Bennett wrote:You can control static by wiping the glass, or plastic, with a dryer sheet. Lasts a long time.
I use the furniture polish "Pledge"
It cleans and shines plexiglass and gets rid of static as well.
I'm guessing the dryer sheets have a waxy substance that achieves the same result.
jimmc
Jan Thu 01, 1970 12:00 am
Peoria Arizona 85383 USA
Post by jimmc »
I found if you just breath on the plastic meter glass it kills the static charge
Jim
Dave Wise
Feb Wed 07, 2007 11:36 pm
Hillsboro, Oregon
Post by Dave Wise »
Discussions of this issue are archived on the HP-Agilent-Keysight mailing list at groups.io .
When my HP 400EL scale started peeling, I trimmed a self-adhesive smartphone screen protector to the appropriate size and stuck it to the scale. A year later it is still good. It was tricky to cut out the region in front of the mirror.
devildog63
Carrollton GA 30116
Thanks for all the ideas. I sealed the face with clear sealer. Looks good. Before that I made several scans and prints for future needs.
Now I'm having a hard time finding the age of my meter. My serial number is 0979A13504 . I have a operating and service manual but it calls for a xxx-xxxx serial number. Anyone have insight to this ?
Thank you.
KM4YTW
Dave Wise
Hillsboro, Oregon
Post by Dave Wise »
For the best estimate of year of construction, look at date codes on components. Artek sells manual 03400-90008 that covers your serial number prefix.
Post Reply
