It is currently Jan Tue 19, 2021 3:53 am
 Post subject: What tube tester to test a 12CA5??
PostPosted: Feb Tue 11, 2003 4:51 am
Hi all,<BR> OK, now I,ve got one. I have quite a few testers but none list a 12CA5 tube. Does anybody know of what testers that are available to test this tube? I have all the I-177's which of course do not list it. I have a Sylvania Electric,model 140 and a Radio City,model 315. These don't list it. Is there a way to use these testers for another number tube such as a 6--- and increase the filament voltage?<BR>Thanks and take care<BR>Bud<BR><P>------------------<BR>
PostPosted: Feb Tue 11, 2003 6:12 am
12CA5 is Beam Power Amp.<BR>Pins 3-4 Filament 12.6V 0.6A<BR>Pin 1 Cathode/Grid 3<BR>Pins 2 and 5 Grid 1<BR>Pin 6 Grid 2<BR>Pin 7 Plate<BR>Set tester for 12V Filament.<BR>Find setting for a known beam power amp. Transfer pin numbers. Should be somewhere close. I'm sure someone else can be a lot more exact.<P>------------------<BR>
PostPosted: Feb Tue 11, 2003 9:30 am
Hi Bud<P> Other tubes with the same base wiring are 6AS5, 12C5, 12CU5, 12R5. There are others. <P> I am sure you will find 6AS5 on a tube tester. As whertel mentions change the filament to 12 volts and it will test. <P>------------------<BR>Norm
PostPosted: Feb Tue 11, 2003 6:43 pm
Hey whertel and Norm,<BR> Thanks for the info. I do have a listing for a 6AS5 for the I-177 with adapter Mx-949.<BR>As usual, the help is always here by the many experts.<BR>Take care<BR>Bud<BR><P>------------------<BR>
PostPosted: Feb Tue 11, 2003 9:58 pm
Also the 50C5 has the same basing<P>------------------<BR>
Users browsing this forum: KX5JSC, pauls.ironhorse and 20 guests
