It is currently Mar Thu 21, 2019 8:45 pm
 Post subject: Another RCA Victor Special Model Restoration
PostPosted: Mar Mon 11, 2019 1:56 pm
Another RCA Victor Special Model M restoration. This is my sixth restoration of one of these. None are mine, sadly. These machines, designed by industrial designer John Vassos, were produced in 1938-1939 for the 1939 World’s Fair. The motor is hand cranked and the amp is battery powered.
The amp is powered from a 1.5v/90v AB Battery. There is one electrolytic cap and four wax/paper caps to replace. I stuff the new caps inside the old caps. The bias battery is replaced with a 1M resistor. I replaced three other out of tolerance resistors. All the tubes were good. The tube line-up is 1G6, 1A5, and a 1H5.
The Astatic crystal cartridge was dead, of course. I sent it to Gib Epling at West-Tech Services for rebuilding.
The motor in this machine was in very good condition. The only service required was to wipe off some old grease and lubricate the pivot points in the mechanism.
I made a new battery and connector. The battery uses ten 9-volt cells in series for the B supply and two D cells in parallel for the A supply.
Here's a link to a short You Tube video:
https://youtu.be/Q7qBmzevmjE
Ed
 Post subject: Re: Another RCA Victor Special Model Restoration
PostPosted: Mar Tue 12, 2019 7:33 am
Ed you must be the restoration expert on these then. They are beautiful sets, but it would take a good chunk of gold from Fort Knox to own one.
PostPosted: Mar Tue 12, 2019 12:55 pm
Thanks, Larry. The owner of the machine shown here paid three big ones for it on eBay. I’ll never own one.
Ed
PostPosted: Mar Thu 14, 2019 9:17 pm
Where'd you get the battery cover? :-)
PostPosted: Mar Fri 15, 2019 1:54 am
I make them. One of my earlier RCA Victor Special Model M customers had scans that I have modified to fit my boxes.
Ed
Post New Topic Post Reply  [ 5 posts ]  Moderator: Alan Voorhees
