It is currently Jan Tue 28, 2020 1:36 am
 Post subject: VM 1210B drops 45 but the tonearm moves to the LP position
PostPosted: Aug Tue 13, 2019 11:02 pm
Hi Folks,
Last year I did a complete teardown and rebuild of a VM 1210B for my Westinghouse Model 57ACS 2 record player as well as rebuilt the amp. Everything worked great or so I thought. I recently tried to play some of our 45 records and was surprised to see the record drop but the tone arm only moved to the 33-1/3 position. It took me by surprise but I did catch the arm before it hit the turntable mat.
I am hoping somebody that has run into this before can guide me on what part or parts I need to re-clean and re-lube to resolve this problem. Your advice will be greatly appreciated.
Ernie
 Post subject: Re: VM 1210B drops 45 but the tonearm moves to the LP positi
PostPosted: Aug Wed 14, 2019 3:00 pm
There is a little metal "flag" that a 33 sized record hits while dropping to the platter. It should be spring loaded and freely moving. It might be gummed up and stuck in the 12" record position
PostPosted: Aug Thu 15, 2019 3:55 am
In addition to what Meatloaf said, make absolutely certain you got all the old grease out. You would very surprised in the places it still exist even after you though you had it all out.
PostPosted: Aug Thu 15, 2019 12:21 pm
Meatloaf Lover and Artcurus,
I have stripped it down and will reassemble then let you know how it works out.
Ernie
PostPosted: Aug Thu 15, 2019 5:32 pm
Also this style of VoM changers are built slightly different and are more picky if that makes sense. Pay close attention during reassembly, in fact taking pictures would be a good idea. Something as simple as a washer in the wrong place or wrong position can really mess things up
PostPosted: Aug Sat 17, 2019 3:54 pm
Artcurus and Meatloaf,
Thanks for your advice. I cleaned the 33-1/3 flag and spring area and reassembled everything yesterday. I played several stacks of 45s last evening and the tonearm now drops where it is supposed to.
I appreciate your good advice.
Ernie
Users browsing this forum: Ken Doyle, OldRestorer and 5 guests
