It is currently Jul Mon 13, 2020 2:40 am
 Post subject: BSR UA15SS Turntable start position adjust
PostPosted: Nov Wed 28, 2018 8:31 pm
Hi All,
I'm fixing up a BSR turntable that came out of a Sears Console. It has a label inside that says:
UA15SS.A-3D
PS1108U.76
I've got it working okay now except for one thing. The auto start drops the needle a little to far in, in the middle of the 1st track of a record.
How do I adjust this?
Sam
 Post subject: Re: BSR UA15SS Turntable start position adjust
PostPosted: Nov Thu 29, 2018 12:06 am
Some of the tonearms in these are of different looking style.
The tonearm stylus set-down screw, though, should be the same.
Hotwax
PostPosted: Dec Tue 04, 2018 8:09 pm
Hotwax
Thanks! I got that adjusted. But now the auto return doesn't trigger at the end of the record.
Also the record drop spindle stopped working :(.
Sam
PostPosted: Dec Tue 04, 2018 8:41 pm
Sam
Alright fixed the spindle. It had a bent piece.
It seems like the auto-return position is set by the same set-down screw as well. Is that true. Maybe I can find a position that works for both...
PostPosted: Dec Tue 04, 2018 10:41 pm
got it
PostPosted: Jun Tue 30, 2020 3:13 am
I have the same model we are trying to work on but I can't seem to find any replacement belts that size. We measured 733 mm or 28 3/4. seems awfully large. also the writing is kind of worn off, what does it say on the second knob down besides FM/AM? thanks.
