It is currently Oct Tue 19, 2021 7:36 pm
 Post subject: Removing only the turntable from a rp 190.
PostPosted: Sep Sat 25, 2021 4:00 pm
I need to remove only the turntable from a rca rp 190. The turntable cracked and needs to be glued back together. The only videos I've found on you tube doesn't show this. HELP please and thanks.
 Post subject: Re: Removing only the turntable from a rp 190.
PostPosted: Sep Sat 25, 2021 5:57 pm
If you are new to changers / record players, take lots of photos / make drawings or you will get lost.
The late Chris Cuff has disassembly and reassembly videos for RP-190 on his youtube channel.
Channel search→ https://www.youtube.com/user/fortyfivep ... ery=RP-190
RCA 45 RPM changer RP-190 Turntable reassembly
Watch: https://www.youtube.com/watch?v=2P2XSWO88xM
RCA RP-190 45 Record changer disassembly
Watch: https://www.youtube.com/watch?v=Rq5JP2h5yPQ
His how to videos are excellent, - - and... Sams Photofact Set-144 Folder-7 is attached to this thread.
→ viewtopic.php?p=3361713#p3361713
Factory service manual: https://ia601305.us.archive.org/17/item ... 20Data.pdf
PostPosted: Sep Sun 26, 2021 2:14 pm
Thanks for those links. They aren't showing how to just remove the turntable. Is there any way to do this?
PostPosted: Sep Sun 26, 2021 3:41 pm
Unfortunately, much of the mechanism has to come apart to remove the turntable.
As record changers go, this is one of the easier ones to tear down for cleaning and lubrication. Upon reassembly, the adjustment sequence found in the factory service manual (linked above) should be followed in order.
PostPosted: Sep Sun 26, 2021 3:44 pm
Everything on the turntable shaft below the deck has to be removed.
PostPosted: Sep Sun 26, 2021 3:45 pm
below
PostPosted: Sep Sun 26, 2021 5:15 pm
Thanks everyone. Maybe I didn't make myself clear enough. The platter itself is cracked and I need to glue it back together.
PostPosted: Sep Sun 26, 2021 5:16 pm
I have it taped together but want a more permanent fix. Thanks again.
PostPosted: Sep Sun 26, 2021 5:20 pm
You were quite clear. To remove the turntable, remove the gear under the chassis and everything above it, including the knurled collar that drives the cycling cam. With the knurled collar removed, the turntable and spindle assembly just lifts out.
-David
PostPosted: Sep Sun 26, 2021 5:37 pm
Thanks everyone. Will work on this tomorrow and report back. Have a great Sunday.
PostPosted: Sep Sun 26, 2021 6:20 pm
I hate to be the bearer of bad news but thst might not be repairable. Yoy might have to consider a parts unit.
PostPosted: Sep Mon 27, 2021 2:42 pm
I have it taped together so I'm figuring gluing will be even better. The tape works quite well. This is actually the best playing 190 that I own at this time. It's just cosmetics that don't look good.
PostPosted: Sep Mon 27, 2021 4:07 pm
As others have noted the best solution would be to source a used turntable - but - see https://www.ebay.com/itm/133401662088?h ... Sw6PpeTe56 - after careful gluing and using this mat it should look almost new. (Note - I have not used one of these mats and my one attempt at rebuilding a RP 190 was 'less then fully successful...... :cry: )
PostPosted: Sep Tue 28, 2021 10:54 am
Have you had the cam and drive wheel redone? This must be done because they are on borrowed time. Send both to Gary at thevoiceofmusic.com.
About the cosmetics, once the slide is out, there's not much left, and unit can be disassembled, cleaned up and repainted. Take pictures as you disassemble to keep track.
Are you modifying for stereo?
PostPosted: Sep Thu 30, 2021 2:11 am
Everything inside has been refurbished. Have glued the turntable together and ordered a new mat to hide the crack.
Post New Topic Post Reply  [ 15 posts ]  Moderator: Alan Voorhees
