It is currently Dec Mon 06, 2021 12:26 am
 Post subject: Rp205 motor shaft spring pulley
PostPosted: Nov Thu 25, 2021 12:57 am
Hi everyone. I’m finally getting my SHF7 working and have had a heck of a time getting it to run at speed. I found out today from VOM that the motor shaft is supposed to have a spring over the shaft to drive the turrets. Does anyone know where I can get one? VOM doesn’t have any and suggested I try some forums or find a RP205 for parts.
Thanks in advance for any information. If someone has a rp205 with this motor, would you be willing to measure the diameter of the spring on the shaft with a caliper or micrometer?
 Post subject: Re: Rp205 motor shaft spring pulley
PostPosted: Nov Thu 25, 2021 3:17 pm
Hotwax wrote: You will not find the spring pulley by itself anywhere.
viewtopic.php?p=3428229#p3428229
Place a WTB (wanted to by) Ad. in the classified forum here at arf...
You can bump the Ad. every seven days - - - (reply to your post).
You will need to include your City or Zip in your profile.
via... User Control Panel.
Read the posting rules for that forum→ viewforum.php?f=15
At times It is best to include a photo of the required item.
fyi… the late Chris Cuff describes some common faults and repair methods in the RP-205 here…
https://www.youtube.com/user/fortyfivep ... uery=rp205
Chris' repair and restoration videos are excellent.
Here's a classic→ viewtopic.php?p=3361713#p3361713
PostPosted: Nov Thu 25, 2021 3:24 pm
RP-205 series... changer service manual.
20MB→ download/file.php?id=379528
Amplifier chassis RS-164 and RS-164A
attached below.
SAMS 395-11.pdf [3.54 MiB]
Downloaded 8 times
PostPosted: Nov Thu 25, 2021 5:00 pm
I'm sorry I don't have an accurate way to measure it, but it looks like the type of spring you may be able to find at the hardware store. I've removed them to be able to disassemble the motors for cleaning and have taken them off and put them back on by holding the rotor and "unscrewing" them with my fingers.
PostPosted: Nov Thu 25, 2021 5:01 pm
spring
PostPosted: Nov Thu 25, 2021 5:22 pm
Mr Google says that Record Changer RP-190A-1 also employs…
spring 76749
Listed here and shown in this 1951 Canadian service manual as SLEEVE 76749
spring sleeve for motor shaft
http://pacifictv.ca/schematics/rca15edata.pdf
also found in US 1952 Automatic Record Changer 930409 Series.
PostPosted: Nov Thu 25, 2021 9:43 pm
Thanks all for the help. I found someone with a bad motor and they are sending me the spring. Can’t wait to get this running!
Post New Topic Post Reply  [ 7 posts ]  Moderator: Alan Voorhees
