I just acquired this Braun MM3 console which I have read were made from 1956 through 1958.
It has a RC61 radio and unknown model Telefunken record player.
File comment: Braun MM 3 Console
Does anyone know how to identify which specific Telefunken record player this is? There are no numbers to be found on either side of the platter.
File comment: Telefunken Record Player
File comment: With platter removed
The only numbera I can find on the underside are 720898 and 1238.00
File comment: View from underside
The center shaft and platter wobble when touched, which is the issue I'd like to fix.
Here's a video which demonstrates the wobble (exciting I know):
https://youtu.be/lvHFDKGrkAoAnd here's a view from underneath that shows a nut that I'm assuming might be the culprit:
https://youtu.be/srD6AwDralcAnd for those who refuse to watch video... here's a pic of the suspect nut, which I have been unable to get a good grip on to secure (one hand is being used to hold a lever from obscuring the view):
What I'd really like to know is
what specific model of Telefunken record player do I have and
do you think it's only a loose nut, or is it more likely to a related bearing?
