Forums :: Web Resources :: Features :: Photo Gallery :: Vintage Radio Shows :: Archives
It is currently Jun Thu 08, 2023 7:53 pm
 Post subject: need help with a Motorola phonograph
PostPosted: May Thu 25, 2023 3:03 pm
i got this at a yard sale and it need some fixing
how do i find out the model number
i found the same unit online but it did not have any information
i will attach a picture
thanks fred
 Post subject: Re: need help with a Motorola phonograph
PostPosted: May Thu 25, 2023 10:20 pm
Welcome to the Phono Forum at ARF.
I believe your model is a 1958 3H25B.
I'm posting the circuit schematic for you, but
you will need to verify the chassis number
stamped on the tube amplifier chassis.
3H25B chassis # is HS-601 or HS-602.
Access to the amplifier is via a bottom wooden panel, rear panel,
and the ventilation panel inside the top of the cabinet.
The amplifier must be serviced with at least new
capacitors to safely function and avoid serious
damage to the power transformer.
This MUST be done, no shortcuts about it.
The record changer is made by The Voice of Music,
and will be a model 1201 or similar.
The changer and its motor should be cleaned thoroughly, and
it may need a replacement idler wheel.
The old phono cartridge can be replaced with a new Pfanstiehl P-228
or similar stereo cartridge to enhance record playing.
When restored completely, this Motorola consolette
will sound really nice.
All needed parts are available for the amp and changer.
Let us know your level of expertise in vintage
tube hi-fi equipment repair, if you are doing
the repairs.
Added the V-M 1201 file.
Hotwax
Motorola 3H25 Beitman-1958.pdf [348.08 KiB]
Downloaded 19 times
V-M 1201 Stereo Changer 436-18.pdf [3.47 MiB]
Downloaded 24 times
PostPosted: May Thu 25, 2023 11:06 pm
Wow
Thank you for the fast reply. As soon as I get my workbench cleaned off I’ll take the wood panel off to verify that that’s the model it is.
I’m a total amateur when it comes to this but I do have a friend who repairs tube radios and he says that this is not much different.
Thanks Fred
PostPosted: May Sat 27, 2023 2:19 am
I had a chance to look at the player
Adding more pictures
So I plugged it in turn down the turntable and a minute or so later started the hum
The platter did not spin or appear to wanna Spin.
Are there any good YouTube videos on how to service the record player?
I’m gonna take pictures to record where the wires go remove the amp and let my friend replace the capacitorS
The cabinet is in really good shape for his age. One of the legs keeps turning out looking funny I am can I put it in the right position and see if I can put a little screw to keep it from moving well that’s also the leg that’s missing the foot And the belt that’s a service part available
Thanks fred
PostPosted: May Sun 28, 2023 8:51 pm
Wow, nice Motorola! Wish I could find one of those for myself.
Jordan Pier on Youtube has an excellent series on servicing VM changers
William
PostPosted: May Mon 29, 2023 4:30 am
Here is Ed's master class on servicing a V-M 1200 series
record changer.
Ed also posts tips on unique features and
pitfalls of servicing a V-M 1200.
viewtopic.php?f=9&t=186294&hilit=restoration+zenith
Idler wheel, phono cartridge, motor mounts, et cetera from
the voice of music dot com.
Turbine oil (Supco Zoom Spout e.g.) is recommended for motor lubrication after
cleaning.
Hotwax
PostPosted: May Mon 29, 2023 9:47 pm
So, after reading about doing a thorough cleaning and checking some things out, I found out the motor was stuck on my tried, giving it a quick lube and was able to get the armature to rotate freely. The motor actually looks pretty new to me compared to the other components, so needless to say I got the turntable to spin and I was able to put a record on and play it but there’s some adjustment issue between the idler wheel and the platter when you’re turning the speed control. It’s very hard to get it to go to 33 rpm
I got an LP to play it didn’t sound perfect but at least I know now it’s functioning so I take it apart and clean it and put it together correctly. It should work.
I know the amp and speakers work, but I still gonna have to have the amp service to put the new capacitors on
Thanks Fred
PostPosted: May Tue 30, 2023 12:17 am
I just realized I don’t have any pictures of the turntable
PostPosted: May Tue 30, 2023 4:28 am
The basket that holds the motor and the shift mechanism needs to be throughly cleaned and relubricated.
To reiterate what Hotwax has stated, the amplifier MUST be rebuilt. If a certain set of parts goes out, it can cause a cascade failure, at the very least destroying the power transformer or at worst, starting a house fire. During the rebuild process, replace the resistors around the output tubes.
Contact Gary at thevoiceofmusic.com for a new cartridge and needle,
and drive wheel for the changer.
PostPosted: May Tue 30, 2023 2:49 pm
i understand the amp needs to be serviced
i will have it done
thanks fred
PostPosted: Jun Thu 08, 2023 1:13 am
Don't forget to replace the 3 rubber grommets that hold the motor to the speed changer mechanism---they are almost always bad, and will cause the motor to wobble. They are available at Voice of Music online
William
PostPosted: Jun Thu 08, 2023 2:36 am
I just got done cleaning and re-lubing to drive motor. I did look at the motor mounts and they are I don’t want to say hard they’re very soft which I’m assuming they’re supposed to be .
I cleaned a lubed the speed selected the motor was mounted to this. It moves very smooth now.
The idler wheel is hard a shiny on the drive edge. I used some rubber rejuvenator on it. I will see how it looks tomorrow when I clean the res of the mechanism.
PostPosted: Jun Thu 08, 2023 2:41 am
Is this middle still available or do I need to switch it out to a cartridge type
PostPosted: Jun Thu 08, 2023 7:59 am
Rubber rejuvenator works but only for a while. You're going to have to replace the idler wheel sooner rather than later. But in the meantime, you can use it to see if there are other problems.
Jim Mueller
Time is SO weird!
PostPosted: Jun Thu 08, 2023 9:43 am
You're definitely going to have to replace that cartridge. I call them record chewers, very harmful to modern records or even stereo records from back in the day. I'd recommend a Pfanstiehl P228, which can also be had from the Voice of Music website.
Motor mounts; it's not whether they're hard or soft, it's all about the amount of play the motor has. The rubber gets "wallowed out" over time, and allows too much motor movement
William
Post New Topic Post Reply  [ 15 posts ]  Moderator: Alan Voorhees
