It is currently Jan Wed 22, 2020 12:53 pm
 Post subject: Rockola 48350-1A amplifier IC 48934 cross?
PostPosted: Oct Sun 18, 2015 8:04 am
From a Sybaris 474, 1978, Amp model 48350-1A. Preamp has a white noise output on one channel but fine in the other. I can't find a cross-reference for this 48934 8-pin DIP IC for the life of me. Has anyone been able to find a drop-in replacement using normal ID numbers?
Thank you!
 Post subject: Re: Rockola 48350-1A amplifier IC 48934 cross?
PostPosted: Oct Mon 19, 2015 9:48 pm
I looked for x-ref in some catalogs but nothing came up. Googled and first entry.
https://www.jukebox-revival.eu/staging/rockola-ic-48934.html
You might can find something with more googles?
Bill J.
PostPosted: Oct Sat 24, 2015 4:38 am
I saw that, thanks. However, I'm looking for the generic cross number so I can get it locally - and isn't this guy in Europe? Unfortunately, the magical Google-fu turned up nothing else for me either. I do have a good lead that says it's a 741 op-amp based on other, earlier Rockola amps.
PostPosted: Oct Sat 05, 2019 12:56 am
ic opamp 741 work well
Post New Topic Post Reply  [ 4 posts ]  Moderator: Alan Voorhees
Users browsing this forum: Tarpawns and 10 guests
