It is currently Jul Wed 17, 2019 4:17 am
 Post subject: SHF 7 my first console
PostPosted: Apr Sat 01, 2017 1:38 am
I just fount a shf 7 and plan to rebuild it(my first). Looking to find information but cannot find the date of manufacture. I have model, ser. number and Reg no. Is there a site I can do serial number lookups?
Thanks for any help I can get.
 Post subject: Re: SHF 7 my first console
PostPosted: Apr Sat 01, 2017 3:45 am
Hello and welcome to ARF Phonos.
I assume this is an RCA SHF-7?
If so, your model is from late 1957 to early 1958.
Chassis/amp is found in Sams Photofact reference: 395-11
The record changer is an RCA RP-205, found in
Sams 358-10
Send me a PM with your email, if you want the schematics.
BTW, what level of expertise do you have in vintage
electronics restoration ?
Do some searches on this forum for threads that deal with
your model.
Same for the RP-205 record changer.
When ready, ask more questions as you go !
Also, post photos of your console.
Hotwax
PostPosted: Apr Sat 01, 2017 3:51 am
There should be a code date stamped on the model / tube chart label, on the amplifier chassis and speakers. a number like 742 would indicate the 42nd week of 1957.
PostPosted: Apr Sat 01, 2017 3:55 pm
Thank you! Exactly what I was looking for. Yes it's an RCAVictor with the legs in very good shape. It makes a very loud buzzing a little bit after you plug it in. I have repaired an old pinball machine years ago and modern circuit boards on a flatscreen tv(bad caps) and he washing machine bad relay with the help of you tube and forums of course. I repaired industrial machinery for over 30 years.
The date code is 739, so that means it's a 57 built in September?
After reading forums and learning a little bit about old tube amps I decided to buy it and start a new challenge.
PostPosted: Apr Sat 01, 2017 5:48 pm
If its a loud Buzzing/Humming sound its likely it has bad main capacitors, when you open it up you will see some tall metal cylinders they are the main smoothing caps.
PostPosted: Apr Sat 01, 2017 9:29 pm
Wow, how's that for a shot in the dark. I was within three weeks of the actual date.
PostPosted: Apr Sat 01, 2017 9:49 pm
Yup. You nailed it!
PostPosted: Apr Mon 03, 2017 12:57 am
Here is the picture of my 1957 RCA Victor SHF 7
File comment: here the picture of my recent find. 1957 SHF7 RCA Victor.
PostPosted: Apr Fri 28, 2017 4:34 am
Very nice! How's the rebuild going?
PostPosted: May Fri 24, 2019 8:00 pm
File comment: I found another one! cannot find any information on this one. Please Help!
Post New Topic Post Reply  [ 10 posts ]  Moderator: Alan Voorhees
