It is currently Jan Sat 18, 2020 10:57 am
Post New Topic Post Reply  [ 24 posts ]  Go to page Previous  1, 2
 Post subject: Re: RCA 1965 Solid State Phonograph Circuit Question
PostPosted: Apr Wed 10, 2019 4:58 pm
Your cartridge is not crystal; it's ceramic. Unlikely any of the three are bad. On solid state phonographs of that era I replace all the electrolytics. You need to try another input. Also, the "grounds" should be correct.
Bill J.
Need to read slower and attentive; mentioned things already stated.
PostPosted: Apr Wed 10, 2019 9:52 pm
Tim, Bill, you're right. It's an Astatic 348, ceramic.
I'll back down the voltage on the signal generator and try again. I'll also look at C6 and C8 and the nearby resistors.
When you say another input Bill, what do you mean?
PostPosted: Apr Thu 11, 2019 12:37 am
You can input from a radio. I've for years have used leads to a transistor radio speaker output with clips attached. I even use the headphone output of my laptop. Any source of audio will do.
Bill J.
PostPosted: May Wed 01, 2019 10:58 pm
Update:
First, thanks for all the help and input. I wouldn't have gotten this far without you.
As mentioned, all the electrolytic and paper caps were replaced and I replaced a few out of range resistors.
I traced the ground to be sure that was correct.
I was able to get a clean signal and scope reading through the first caps C6 and C8 and the first two transistors, SE4002.
It was between X2 and X3 that the sine wave distorted.
I then removed some transistors to test.
Could you take a look and let me know if, with these transistor test numbers, you see a problem?
X2 2N406 Ge PNP
b/c .201
b/e .210
reverse c/b and e/b open open
e/c open
c/e open
hfe 70
X3 40022 Ge PNP
b/c .129
b/e .132
e/c 1.863
c/e open
hfe 90
X6 40022 Ge PNP
b/c .129
b/e .131
e/c 1.517
c/e open
hfe 114
Post New Topic Post Reply  [ 24 posts ]  Moderator: Alan Voorhees Go to page Previous  1, 2
