It is currently Oct Mon 14, 2019 10:34 pm
 Post subject: 7-EY-2HH
PostPosted: May Thu 09, 2019 8:03 pm
Found a Deluxe 3 today in two tone green. I was searching for a schematic and found one here of the EY-1 but, is there a difference between the chassis of the EY-1 and my EY-2?
 Post subject: Re: 7-EY-2HH
PostPosted: May Thu 09, 2019 10:43 pm
Service manual, thanks to Bill J.
viewtopic.php?p=1884265#p1884265
ref-1: https://www.samswebsite.com/en/photofac ... sid/341_13
ref-2: https://www.samswebsite.com/en/photofac ... msid/355_8
PostPosted: May Mon 27, 2019 7:33 pm
Changed most of the resistors and all of the capacitors...new needle/cartridge from China (cheap); it sounds great. Next I address the cycle problem (it doesn't nor does the reject switch do anything). I have a new rubber tire for the cycle cam (from William Bosco) and when time allows will change out the rubber on the cam. I hope that fixes the reject problem as well as the cycle issue. Do you think it will? Thanks all.
PostPosted: May Tue 28, 2019 5:26 am
If the new rubber for the changer cam doesn't solve the problem...look at the mechanics attached to the reject slide switch...That switch should engage and push the vertical tang on the cam wheel off the null spot, which starts the reject cycle.
PostPosted: Jun Wed 05, 2019 10:36 pm
OK, put the new tire on the cycle cam and all works well. My only concern now is the tone arm seems to drop HEAVY and has some jerkyness decending to the record. 4 grams weight at the stylus?
PostPosted: Jun Wed 05, 2019 11:40 pm
For reference: Solved this jerky problem. The new cycle cam tire has a bump at the glue joint. Thanks.
