It is currently Jul Thu 18, 2019 10:50 pm
 Post subject: Perpetuum Ebner Rex
PostPosted: May Thu 23, 2019 12:37 am
I come begging folks. This turntable has multiple issues. Namely, the cartridge will not stay in place to add it "ist kaput" with no output directly wired to a phono input, that is to say not trusting their mounting assembly.
Next, the "kondensator ist kaput". It measured 4nF as opposed to the 350nF as printed on it. Also it leaked goo allover the mounting board.
To add insult to injury, one of the wires broke off the terminal board when moving the board to clean it off.
The power switch is all split open with pieces that were rattling inside.
Does anyone have a wiring diagram for this thing, a replacement cartridge & stylus, and a replacement tonearm power switch?
Disaster photos are available if needed.
Please help. Thanks.
 Post subject: Re: Perpetuum Ebner Rex
PostPosted: May Thu 23, 2019 3:08 am
Hi Sparky and welcome to the phono forum.
Try over here at this site for your manual.
They are a large group and many Euro members
who are PE owners.
Good luck,
Hotwax
https://www.vinylengine.com/library/per ... bner.shtml
PostPosted: May Thu 23, 2019 4:54 am
Thanks for the link but nothing was found under all of the REX's. I checked all of the others and no go. Mine is wired differently, as well as the PE10 cartridge. Strictly a EU unit. It was brought over with the voltage at 220 with the EU plug.
PostPosted: May Thu 23, 2019 2:47 pm
I usually junk these PE turntables when they are in pretty bad shape (they are usually the weakest link in these German sets) and fit a newer Garrard, BSR or similar consumer makes from the 70's in there....if your set is a 120vac model.
PostPosted: May Fri 24, 2019 7:11 pm
And your comments help me repair this how?
The owner does not want a refit.
PostPosted: May Sat 25, 2019 2:51 pm
:roll: I merely gave my solution as an option to you, based on having worked with a number of these sets with PE turntables in poor condition... You didn't indicate there was no option to replace it.
PostPosted: May Sun 26, 2019 10:30 am
Thats a nice turntable. Is the automatics working as it should? You can try to turn the turntable by hand and press the start button for o while.
Im not sure what the condensatir schould be, but the P E REx Deluxe use 1,6uF.
PostPosted: Jun Wed 12, 2019 5:26 pm
Hi,
There is a lot to do, maybe you need some parts for it, more than recapping.
Please enter this forum, you can ask in english and they answer you in english.
You only have to deal with the login datas:
https://www.dual-board.de/
Start your career here:
The top line says: Anmelden oder registrieen? / go on that
For registering click that sentence:
X Nein, ich möchte mich jetzt registrieren.
Then, after registering go on:
https://www.dual-board.de/index.php?boa ... eh%C3%B6r/
There you will find all answers of what you need!
Good luck
PostPosted: Jun Sun 16, 2019 2:00 am
What is model name and model number of the unit in which this changer was installed?
Bill J.
Post New Topic Post Reply  [ 9 posts ]  Moderator: Alan Voorhees
