It is currently Oct Sat 19, 2019 3:51 am
 Post subject: Seeburg Select-O-Matic '100' Mechanisim Question
PostPosted: Jun Thu 06, 2019 4:14 am
Eric or other Seeburg jukebox fanatics...will a select-o-matic '100' mechanism model number 145S7-L6 fit function in a jukebox that had 145S14-L6 previously installed as long as the gear ratio is the same (38.75)?
Thanks!!
 Post subject: Re: Seeburg Select-O-Matic '100' Mechanisim Question
PostPosted: Jun Fri 07, 2019 3:11 am
I don't know for sure but I think all the Pinbank models use the same basic turntable mechanism, the contacts and maybe some brackets may be different. the gear ratio is irrelevant since it's going to run at 45 RPM regardless.
I'm guessing this question is about the one for sale on eBay? That one is from an M100C, what model is yours?
PostPosted: Jun Sat 08, 2019 7:45 pm
Hi Eric,
No, I have several mechanisms I have collected over the years and they are all seem basically the same for the 100 series, Some have different colors and different cartridges. [u]I think[/u] it is a "B" model mechanism I am thinking about putting into a 100 R.
Thanks for the reply!
PostPosted: Jun Sun 09, 2019 6:57 am
I think it will work but you'll probably have to use the contact switches from the R. I know the B & C contacts are different, the C has a mute? contact that the B doesn't, I don't know if that applies to the R or not but it seems likely it'll be different than the B.
The person who would know for sure would be Ron Rich at http://jukeboxaddicts.proboards.com/
