It is currently Jul Wed 17, 2019 5:45 am
 Post subject: Loud hum when touching the metal
PostPosted: Jun Fri 07, 2019 6:28 pm
While working on my 7-EY-2HH it developed a hum that increased in intensity when I would touch the metal parts of the player. Having been in and out of it several times making adjustments I thought I had broken a shielded wire or one of the wires was touching something it shouldn't be. Checked the cartridge connections several times also. One of the last times I had it unplugged and re-plugged in the hum was gone. After checking more things I figured out that the plug was not marked for polarity and I could plug it in two different clockings. Bottom line is when I plugged it in observing polarity there is no hum. My thinking is the chassis ground (?) connects through the neutral wire of the plug and if i plug it in observing that there is no hum.. Is this a normal thing or is something mis-wired in the chassis? Thanks.
 Post subject: Re: Loud hum when touching the metal
PostPosted: Jun Sat 08, 2019 4:53 am
just make sure the polarity is correct when plugged in. no hum=correct
PostPosted: Jun Sat 08, 2019 6:46 am
With ac/dc amplifiers, this is common. As Arcturus said, just reverse the plug in the outlet
William
Post New Topic Post Reply  [ 3 posts ]  Moderator: Alan Voorhees
