It is currently Dec Sat 07, 2019 1:00 pm
 Post subject: Philco RP-2 Wireless Record Player -- Antenna
PostPosted: Jun Tue 11, 2019 2:22 am
My brother and I are troubleshooting a Philco RP-2 wireless record player that I just bought.
Does this unit use an antenna to transmit the sound to an AM radio -- frequency somewhere around 540 to 580? I do not see any place on the chassis to attach an antenna -- but in a YouTube video of one of these players the owner shows a long wire antenna strung across the wall/ceiling.
The unit looks good but no sound is getting transmitted. I hope to replace the two tubes which currently glow only slightly.
Thanks.
Mid-1930s Deco Radios & Pre-War Televisions
http://www.collectorkevin.com/radios.htm
 Post subject: Re: Philco RP-2 Wireless Record Player -- Antenna
PostPosted: Jun Tue 11, 2019 6:39 am
Here are 3 threads and links to Nostalgiaair schematics.
Hotwax
https://www.antiqueradios.com/forums/vi ... w=previous
https://www.antiqueradios.com/forums/vi ... hp?t=33908
http://www.nostalgiaair.org/pagesbymode ... 014188.pdf
http://www.nostalgiaair.org/pagesbymode ... 014187.pdf
PostPosted: Jun Tue 11, 2019 10:05 am
Before you replace any tubes, replace the two 6 uF Electrolytic caps with two 10 uF caps and test it. There is no antenna connection, according to the print, and it should broadcast up to 50 feet away.
Post New Topic Post Reply  [ 3 posts ]  Moderator: Alan Voorhees
