It is currently Jul Sat 20, 2019 5:03 am
 Post subject: silvertone 8153-A
PostPosted: Jun Wed 12, 2019 1:06 pm
I am looking to remove the turntable an bearing on this 8153A . from underneath I can remove the pin and slide out the spindle and there is what looks a union nut (that the spindle went through) . I tried (socket wrench) a little pressure to turn it ,with no results . Is this the correct way to remove it ? I did remove the flywheel and it is left hand thread , but bolt head is marked . What do you think ?
 Post subject: Re: silvertone 8153-A
PostPosted: Jun Wed 12, 2019 4:23 pm
. union nut is by silvertone tube has spindle through it .
PostPosted: Jun Sat 15, 2019 7:02 pm
The changer is an Utah 7000? If so do you have the SAMS 27-31 service data. Perhaps it will give a breakdown.
Bill J.
PostPosted: Jun Sun 16, 2019 2:24 am
I don't , but I know more now then I did a minute ago . I'll look around on web , thanks bill
PostPosted: Jun Wed 19, 2019 3:16 pm
Yes its a Utah 7000, I was able get the SAMs free . This little guy is cleaned and lubed and works and plays fine . Image
Post New Topic Post Reply  [ 5 posts ]  Moderator: Alan Voorhees
