It is currently Jul Fri 19, 2019 11:00 am
 Post subject: Need help locating schematic for Magnavox 1ST626 phonograph
PostPosted: Jun Thu 13, 2019 8:32 pm
Need schematic for Magnavox 1ST626 phonograph Stereo.
The Tuner has a number 5930-00 and the amp has a number 8601-10.
Not trying to restore the unit just want to try my hand at FM alignment, I have the necessary equipment. A number of the SAMS would be great if anyone could supply that.
 Post subject: Re: Need help locating schematic for Magnavox 1ST626 phonogr
PostPosted: Jun Thu 13, 2019 10:50 pm
AMP: Sams 550-10 circa 1961
TUNER: Nothing in Sams with that chassis #5930 00
Hotwax
PostPosted: Jun Fri 14, 2019 4:09 am
Unless you can locate the Magnavox documentation (if it exist) see what you can do with
https://www.samswebsite.com/en/photofac ... msid/454_1
Bill J.
I might be able to scan the appropriate sheets tomorrow. Got to dig it out, it's a TV combo.
PostPosted: Jun Fri 14, 2019 1:12 pm
Thank you both for your responses.
PostPosted: Jun Fri 14, 2019 3:11 pm
Here is link to some info. Should be somewhat like your tuner. Hopefully close enough you can use it.
Bill J.
https://app.box.com/s/2i72zhv7k5kd6iurz79l44nwe8f13490
PostPosted: Jun Wed 19, 2019 7:29 pm
Thanks Bill J.
This is what I was looking for.
I appeciate that you took the time to supply what I needed.
Again thanks.
