Post subject: Webster Chicago 100 - Emerson Radio Cabinet
Posted: Jun Tue 18, 2019 5:43 pm
I was fortunate to get this cabinet a couple of months ago, Radio works fine, and has sound. The turntable rotates for all the speeds (33-45-78). But looks like the needle is not working (I lightly rubbed it to test for sound, sorry if it is the wrong way to test it), anyone has experience replacing/changing the needle?
I also have the original manual
Turntable: Wester Chicago Model 100-1
Thank you for any help.
Post subject: Re: Webster Chicago 100 - Emerson Radio Cabinet
Posted: Jun Wed 19, 2019 3:56 am
Joined: Nov Mon 05, 2007 11:08 pm Posts: 2908 Location: Calgary Alberta
https://www.google.com/search?source=hp ... kA6d3GNYrI This link should put you on to ''the voice of music'' I believe that if you give them the make and model number of your turntable or the cartridge number, they can help you . If the link does not work google ''the voice of music'' Dan in Calgary
Posted: Jun Wed 19, 2019 4:16 am
Joined: Jan Wed 16, 2013 12:04 am Posts: 1619 Location: 77001
Welcome to the forum.
Before you go any farther, has this unit's chassis been electrically restored ?
This must be done to prevent damage to yourself and the electrical circuits.
Minimum of all old capacitors (electrolytic and wax/paper) must be replaced. Resistors should be checked to be w/in specs. Tubes checked for possibly shorts. Wiring visually checked for insulation integrity.
