It is currently Jan Wed 22, 2020 12:44 pm
 Post subject: flip over cartridge question
PostPosted: Sep Sun 22, 2019 11:56 am
I am trying to put the knob on a flip over cartridge and the screw is so small it is hard to hold it to insert in the hole of the knob and in to the shaft of the cartridge how do you hold the screw thanks.
 Post subject: Re: flip over cartridge question
PostPosted: Sep Sun 22, 2019 2:02 pm
magnetize the screwdriver by running along the back of the speaker.
PostPosted: Sep Sun 22, 2019 2:41 pm
My father taught me this one...not pretty..but it generally works. Put a good amount of saliva (yes, spit, saliva, etc.) on your screwdriver and the screw and join them up....You'd be surprised how it can hold small stuff like you're working with in place...and evaporates when you're done.
PostPosted: Sep Mon 23, 2019 8:04 am
You can rub the head of the screw on a bar of soap so that the slot fills up. Then stick it on the screwdriver. It doesn't evaporate when you are done.
PostPosted: Sep Mon 23, 2019 12:14 pm
Thanks every one we finally got it with the help of a friend. I had to hold the cartridge from moving and pull it forward and we got it by magnetizing a screw driver.
PostPosted: Sep Mon 23, 2019 9:08 pm
I thought that is what the wax on old capacitors was for :)
Brian McAllister
Sarasota FL
http://oldtech.net
PostPosted: Sep Mon 23, 2019 11:01 pm
I'm also a fan of using silly putty to hold screws or bolts to the driver to keep them from falling out. I used the technique last when installing the very small (and short) push-button switch screws on the inside of my Zenith 8S359 8)
My collection: https://www.radiomuseum.org/collection/ ... ickel.html
Post New Topic Post Reply  [ 7 posts ]  Moderator: Alan Voorhees
