It is currently Oct Thu 21, 2021 12:41 am
Post New Topic Post Reply  [ 74 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Zenith auto changer issue
PostPosted: Jul Sat 17, 2021 1:30 am
Please describe the hot resistor and post schematics.
-David
PostPosted: Jul Sat 17, 2021 5:58 pm
Here is the Sams with the full schematic
The hot resistor is R139, in the power circuit. That one and R140 right below it were both measuring low when I first started work on this. R139 is supposed to be 50Ω and was measuring 38Ω. And R140 is supposed to be 120Ω and was measuring 104Ω. The schematic says they should be rated to 3W and 2W, respectively. I replaced them with 50Ω and 120Ω resistors rated at 5W.
You'll see in the power circuit that there is supposed to be 68VAC across the two red wires coming out of the transformer. When I plug this unit into the wall, I'm getting 72VAC there, and R139 was getting so hot that I could feel heat radiating off of it with my hand an inch or two away from it. I used a variac to dial that 72VAC down to 68VAC. When I did that, R139 was still very hot to the touch, but was not radiating heat like before.
The current through R139 was 0.2A, and the voltage drop across it is around 10V. So it was putting out about 2W of heat. The 3W resistor should be able to handle that but it must have been getting fried since it was losing some resistance over time. I also don't know if a sawtooth wave might impact a resistor more than a nice flat DC voltage.
PostPosted: Jul Mon 19, 2021 8:00 pm
Anyone have any additional thoughts on this bass hum issue?
It honestly may be a bad bass pot. That may be the simplest explanation, since dialing it down makes the hum go away. All the pots were in pretty bad shape when I inherited this one, and I've used a couple rounds of the Deoxit fader lube on them. Maybe there is still some kind of issue with the one bass pot.
PostPosted: Jul Wed 21, 2021 7:50 pm
Last thing I will say about this is that I have also complained about the turntable having a lot of background noise. After all I've done with this one, I don't think it's a mechanical problem. I think this receiver is just so damn sensitive to bass that it is picking up some low frequency vibration from the turntable and amplifying the crap out of it. In phono mode, the bass is even more aggressive than other modes. If I dial bass down to about 20% in phono, it removes most of that background noise and still has what I would consider a normal amount of bass. In other modes I dial it back to about 35% and it gets rid of the bass hum and still has plenty of bass.
Why could bass be getting over-amplified? Is it likely just due to the fact I have higher voltages in the power circuit? Or could it be something else?
PostPosted: Jul Thu 22, 2021 6:27 pm
Interesting idea. The most common reason for excessive bass in an amplifier is a failed capacitor in a feedback look. But looking at the schematic in the previous thread, I can see only one feedback look with no capacitors that are likely suspects.
Maybe measure the frequency response of each channel to see what is up. You can use your laptop or phone as an audio generator if you don't have one. There are apps for that.
-David
PostPosted: Jul Thu 22, 2021 8:47 pm
-David
I actually did a ton of that already. This thread in the restoration forum starting about page 9 has all that info:
viewtopic.php?f=6&t=395789
There is some noise present in both channels, but in the bad channel it's about 7X more (5mV versus 35mV, then they get amplified from there)
PostPosted: Jul Fri 23, 2021 4:48 am
You actually didn't. You only used a 60Hz tone, which is a really bad choice because it is the same as a common hum frequency. Here is how a frequency response measurement is performed:
1. Connect your phone output or PC line card output to the tape inputs of the amplifier if present, otherwise phono.
2. Connect load resistors across the speaker outputs. They should be approximately the same resistance as the speaker impedance (10 ohms is fine if you use 8 ohm speakers), and should have a power rating of 2 to 5 watts at least.
3. Connect your scope across each speaker output in turn. Pay strict attention to which speaker terminal is grounded, and be sure to connect the scope ground to that one.
4. Set the bass and treble controls at their centers of rotation. Set the volume control about 2/3 up. This is to avoid the loudness compensation which affects frequency response.
5. Set the audio generator to 1kHz and adjust the generator level so you get about 3V RMS. Remember that the scope reads peak-to-peak voltage, so you need to divide by 2.83 to get RMS. So you would be looking for about 10V peak-to-peak, which would be about 1 watt RMS into a 10 ohm load.
6. Then without changing the generator level, read the output voltage at the following frequencies: 50Hz, 100Hz, 200Hz, 500Hz, 1khz, 2 kHz, 5 kHz, 10 kHz, and 15 kHz.
7. Measure both channels and report back.
-David
PostPosted: Jul Fri 23, 2021 4:46 pm
-David
You didn't read everything because I later used a 780Hz tone after initially doing that 60Hz tone. The 780Hz tone was picked because it seemed to be a particularly bad one for this issue for whatever reason
Also, I can detect the hum without even putting a signal into the unit at all. It exists on its own
PostPosted: Jul Fri 23, 2021 9:54 pm
One problem at a time. If we find that one channel is boosting low frequencies and fix that, it might cure the hum.
-David
PostPosted: Jul Sat 24, 2021 7:30 pm
I don't have a 10 ohm resistor handy so I'm using the actual speakers (and earplugs!)
I have my phone hooked up to the tape input and a tone generator app set at 1 KHz. I have the bass and treble knobs at 50% and volume at 70%
Even with my phone input at max volume, the highest I get is about 2V peak to peak at the speakers. I don't get close to 10V peak to peak. I could dial the volume knob higher than 70% but I doubt I'd reach 10V (and it's already too loud as it is!)
Likely totally unrelated but just fyi - I also notice a ground hum now that varies with volume. It doesn't get real noticeable until you go above 50% volume. When I've had a ground hum in the past, I could greatly reduce it by making sure the chassis and tape input wire shielding were grounded to the cabinet. Those grounds are in place but there is still a pretty bad ground hum. I rarely turn it above 40% volume so maybe it's been there all along and I just didn't notice. The ground hum vanishes whenever there is a signal. So even if I have my phone putting in a signal but with the volume turned all the way down to zero, there is no ground hum. After I hit "stop" on my phone, the ground hum comes back abruptly after 2 or 3 seconds. The ground hum is a bit worse with the phone disconnected, but the cable still connected to the tape input.
PostPosted: Jul Sat 24, 2021 9:02 pm
Hum when an open cable is connected to a high-impedance input would be normal. Do the frequency response runs and let's see the results. We're looking to see if there is a big low-frequency boost in one or both channels.
-David
PostPosted: Jul Sun 25, 2021 12:32 am
Here are the numbers. These are peak to peak voltages. The 1kHz frequency happened to be the lowest one. I got several that were much higher. The left channel is the one with the bass hum.
FWIW, the ground hum is measuring about 1V on the left channel and maybe 0.3V on the right channel in between these runs with the phone plugged in but no signal.
PostPosted: Jul Mon 26, 2021 6:15 pm
That about a 20dB bass boost and about a 6dB treble boost, just glancing at the numbers. Please try two more frequency runs: 1) volume control up full, bass and treble centered, and 2) volume up full, bass and treble both at minimum.
Let's see if we can figure out what's going on.
-David
PostPosted: Jul Mon 26, 2021 7:14 pm
I'm going to order some 10 ohm resistors before I do this. It's just too loud to do it with the speakers hooked up. It will be a few days.
PostPosted: Jul Thu 29, 2021 3:52 pm
With a 10 ohm resistor in place of the speakers, I am not getting a nice sine wave output. I'm getting weird things like this:
They do change a little with different frequencies, and the volume, bass, treble knobs will increase or decrease the spread of these waves. But all frequencies I try are doing this. This is on the right (good) channel. Is it still worth proceeding with this? The vertical scale is 5V/CM, so the spread in this picture is about 18V.
PostPosted: Jul Thu 29, 2021 4:11 pm
Looks like something is not grounded. Are you sure the scope is grounded to the ground terminal of the speaker output and not the hot terminal? This is critical.
-David
PostPosted: Jul Thu 29, 2021 7:32 pm
-David
There are only 3 speaker wires - left channel, right channel and a common ground. I've only been playing with the right channel right now. I tried it different ways. One was I lifted all 3 wires, and put the resistor between the right channel wire and ground wire, and then put the scope across that. That is the picture I shared. I also tried it where I only lifted the hot right and left wires, and left the ground connected to the terminal in the cabinet. Got the same result. I also for the heck of it tried connecting the black cable of my scope to an actual ground and got the same result.
The 10 ohm 5W resistor is also absolutely getting baked. It will burn you if you touch it. So I'm trying 1kHz right now since I know that was the lowest voltage. It's not getting quite as hot at that frequency.
PostPosted: Jul Thu 29, 2021 9:12 pm
It was user error. I thought I could put in the frequencies in my tone generator and pick them 1 at a time, but it was playing a composite of all of them. Oops.
Here is what I got for peak to peak voltages for all 3 runs you asked for, putting them in 1 at a time:
One thing not captured in the data is that the peaks and valleys of the sine wave was getting chopped off on the runs where the bass and treble knobs were at 50%. Sometimes it was only the peak getting chopped, and sometimes it was both the peak and the valley. This effect was worse on the "bad" left channel. I could get the truncation to go away if I dialed back the volume a bit, or if I dialed back the bass or treble a bit (depending on the frequency). Here is the left channel at 100Hz with volume at max, and bass and treble at 50%. This was possibly the worst one I saw for the sine wave being badly shaped. Not a great picture but the scale is 5V/CM, so it's about 18V peak to trough. The bad left channel was chopping off the peak a little even at 15kHz.
PostPosted: Jul Thu 29, 2021 10:12 pm
Oops, when you do this test you have to be careful not to overdrive the amplifier. The distorted waveform indicates an overdriven condition. You need to reduce the generator level so that the amplifier output is still an undistorted sine wave.
You were getting only about 4 watts. I would have thought this amplifier would be good for more like 20 watts at least before distortion set in. So there is something wrong someplace. If both channels are doing the same thing that points to a problem in the power supply.
But the frequency response is OK. The measurements you took show that the amplifier is basically flat, although the bass control doesn't track very well -- it shows a bit of boost at the 50% setting. Not a problem, but it would boost any hum coming into the input stages.
Yes, 4 watts will make the resistor very hot, but it is rated to take it.
What is the maximum output you can get without distortion at 1 kHz?
-David
PostPosted: Jul Fri 30, 2021 5:46 pm
-David
Uh yeah there definitely is an issue in the power circuit. I explained that back in the first post about this issue. The top 3 voltages in the power circuit are measuring about 5V too high, and the bottom two are 1-2V too high. So instead of -41V for the top one, I'm getting -46V. Instead of -33V, I'm getting -38V. And there is supposed to be 68VAC across the two diodes in the power circuit, and I'm getting 72VAC. I also explained how I put a variac in front of this unit and dialed back that 72VAC so that it was 68VAC. It helped a little but the top voltages in the power circuit were still 3-4V too high.
At 1kHz, I barely get any distortion at max volume on my phone and max volume on the receiver with bass and treble at 50%. Just a tiny bit of distortion. If I turn the phone input down 1 click from max, there is no distortion. Obviously with some of the other frequencies I have to come down a lot more than that to get zero distortion.
Post New Topic Post Reply  [ 74 posts ]  Moderator: Alan Voorhees Go to page Previous  1, 2, 3, 4  Next
