It is currently Oct Sun 24, 2021 8:57 pm
 Post subject: Help with early version RP168 tone arm bouncing?
PostPosted: Aug Wed 25, 2021 4:31 pm
The lightening changing speed of the early versions of the RP168 record changer causes the tone arm to slam down on the record causing it to bounce, sometimes skipping the beginning section of the record!
RCA soon remedied this by adding a small piston mechanism to the changer to slow down the lowering of the tone arm to the record.
Does anyone know how to stop the "slam and bounce" on the early units that did not yet have the piston mechanism built in.
I hope I explained it so it makes sense. Lol.
 Post subject: Re: Help with early version RP168 tone arm bouncing?
PostPosted: Aug Wed 25, 2021 5:04 pm
The best way to fix it would be to find a later parts unit and steal the dashpot out of it.
The other way is to add one of those clip-on tonearm brushes.
PostPosted: Aug Wed 25, 2021 6:38 pm
the best way is to find a unit with the dash pot. It's really easy to install
PostPosted: Aug Mon 30, 2021 6:12 pm
Trick. Remove cartridge. Add a little ring of rubber cement around the mounting holes. Let dry well. Place cartridge back in, but just snug the screws lightly. Makes a shock absorber.
PostPosted: Aug Mon 30, 2021 6:16 pm
double post. <Error>
Post New Topic Post Reply  [ 5 posts ]  Moderator: Alan Voorhees
Users browsing this forum: Azrael and 16 guests
