It is currently Oct Sun 24, 2021 11:25 am
 Post subject: Need repair Audiotronics 300-T classroom tutorette
PostPosted: Sep Sun 05, 2021 11:31 pm
We just bought an Audiotronics 300-T classroom tutorette and the turn table will not turn. We don't want to screw anything up, so I thought I would ask here if anyone might be able to help. We did open it up and discovered a blown fuse. Not knowing what size fuse to get, we are at a stand still. If anyone can help please let me know. Thank you in advance!
 Post subject: Re: Need repair Audiotronics 300-T classroom tutorette
PostPosted: Sep Mon 06, 2021 3:58 pm
1. If you have a blown fuse, there is something in
the circuit that needs repair, or else the fuse would not have melted.
Make sure to leave the AC power cord dis-connected from the AC wall
outlet.
2. Post photos of the record player. Especially of the internal amplifier,
if it is visible.
3. If there is a paper circuit schematic glued onto the inside or
underside of the cabinet, then
we need a sharp photo of the schematic.
Hotwax
PostPosted: Sep Mon 06, 2021 6:32 pm
Ok thank you. I'll do that this afternoon.
PostPosted: Sep Tue 07, 2021 4:20 am
They made both tube and transistor versions that use the same model number; so, what version is yours? Blown fuses can be caused by; but, are not limited to, shorted rectifier diodes, shorted or very leaky filter capacitors, shorted audio output transistors, and a shorted audio output tube. When a fuse blows, something caused it to blow (even if the cause was by a power surge) and this should be investigated. Never replace a blown fuse with a larger amperage fuse and never jump a blown fuse with foil, wire, etc.
PostPosted: Sep Tue 07, 2021 5:48 pm
Sometimes fuses just fail for no good reason. If the fuse is open but not blackened inside, it is likely that the fuse merely fractured. If it is blackened however, it blew from over-current and attention is needed.
-David
PostPosted: Sep Tue 07, 2021 6:31 pm
A good reason is stress fracture of the element. Devices with large inrush currents can incandesce the element, however briefly. Repeat this stress enough times and the element lets go.
Have to add that a classroom phono would not typically exhibit this mode, unless say the inrush was
1) cold filaments plus 2) non-thermionic rectifier.
"Enjoy the fair, George."
